Window squeals
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrdogg619, Sep 15, 2017.
  1. Sep 15, 2017 at 8:02 PM
    Murrdogg619
    Murrdogg619 [OP] Active Member
    Honolulu, Hawaii
    2017 Tacoma Double Cab TRD Off-Road 4x4
    TracRac bed racks, Tint
    My passenger side window makes a loud screetching sound when rolling it down. Does anyone else have this issue. I only have 2k miles on this truck and it's really annoying.
    Cooktop86 likes this.
  2. Sep 15, 2017 at 8:05 PM
    Cooktop86
    Cooktop86 Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
    My driver side did that in the summer. I think dirt gets in the seals an pushes on the window. I took a rag to clean out the seals when the window was down.
  3. Sep 15, 2017 at 8:06 PM
    Murrdogg619
    Honolulu, Hawaii
    i'll probably take the door apart and spray it with silicone spray lube...but i shouldn't have to the truck is only 6 months old...
  4. Sep 15, 2017 at 8:36 PM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    Mine squeals every once in a while. It is annoying.
  5. May 13, 2018 at 9:00 PM
    Murrdogg619
    Honolulu, Hawaii
    bump. any update after using the silicone spray? mine squeals like a pig...
  6. May 13, 2018 at 9:08 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    1. Roll your window down.
    2. Take rubbing alcohol, wet a corner of a rag with it.
    3. Clean the felt seal, both inside and outside.
    Prepare to be amazed at the dirt you will clean off.
    Bridge4 likes this.
  7. May 14, 2018 at 2:39 AM
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    nightcrawler likes this.
