Windshield Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnny_knox69, Sep 15, 2008.
  1. Sep 15, 2008 at 7:04 PM
    Johnny_knox69
    Johnny_knox69 [OP] Well-Known Member
    I need to put a new front windshield in due to big ass rock that went through it.
    Any Idea were to get one to do it yourself?
    Thanks
  2. Sep 15, 2008 at 7:06 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    personally id have a shop do it just cause i dont know how to do it. and i want it done right. but i would check ebay if i was you.
  3. Sep 16, 2008 at 1:20 PM
    Mingy
    Mingy Well-Known Member
    Milton, Ontario
    V6 uble Cab TRX/Towing
    Lear cap.
    I think installing a windshield is one of those things you *really* don't want to try to do yourself. I'm sure if you know exactly how to do it, and have all the right tools, it isn't that complicated, but the knowledge and tools are BIG ifs.
  4. Sep 16, 2008 at 3:17 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    +1
    It's not like you'll be saving yourself that much money anyways, at least in my neck of the woods, they'll come to and install the windshield for next to nothing.
  5. Sep 16, 2008 at 3:45 PM
    Johnny_knox69
    Thats kind of what I am seeing..... As far as a hard job, can't be, it is only glass stuck to the frame. Pop off the cover and then cut the glass from the goop that is stuck to the frame, replace goop and press windshield back...
    I just wanted to know where to buy it direct, not how not to install one.
    thanks guys
  6. Sep 16, 2008 at 3:55 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Go to a Safelight or whatever and see if you can just buy the glass. I think you'll find that you'll pay nearly as much for jsut the glass as you will for having them do it for you.
    At that point- I'll take you longer then it'll take them...so just go for the replacement.
    Also worth checking out your insureance- Many states require full-cost replacements for windshields if you have comp coverage.
  7. Sep 16, 2008 at 4:15 PM
    tjdriscoll
    tjdriscoll Active Member
    07, Tacoma Std Cab, 2WD, 5-M, 2.7 L I4, Indigo
    OEM Foglights, iPod adapter, Bedlights-Underbody lights, more to come soon.
    Your insurance should cover the full cost of the replacement. the windshield is actually part of the "passenger safety system".
    my insurance covered me when i had to replace the windshield on my old saturn.
  8. Sep 16, 2008 at 5:38 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Another thing, if you break it, you will need to buy another, if they break it, it's on their dime.
    Marc M
  9. Sep 16, 2008 at 8:17 PM
    Johnny_knox69
    I hope the new glass is clear like at the rearview mirrror area. I hate that black tint there, and I will put the rear view higher. Can't see good to the right with it in the location it is in.
    Called someone and they said 220 to come and install it where I work or live. Guess thats not to bad.
  10. Sep 16, 2008 at 8:26 PM
    TacoCo
    Colorado
    Not bad at all. I'm kinda curious to see what it'll cost around here to replace mine on my Taco. I'll inevitably get my windshield broken this winter. My last one on my 4Runner literally lasted less than 48 hours, got hit by a rock, and quickly developed a crack. Fortunately, the windshield only cost me $135, installed.
    One trick that I have learned... If a crack starts up on your windshield, you can control where it goes to some degree. Just apply pressure to it with your hand, and you can direct it where to go... kinda helps keeping cracks out of your line of sight.
  11. Sep 17, 2008 at 11:33 AM
    Mingy
    Milton, Ontario
    Lear cap.
    Well, I'm sure any glass place would be more than happy to sell you the glass for you to install yourself. But, having seen it done (and having seen the results of somebody trying to do it), you are way under estimating how hard it is to do yourself properly.
