Windshield Sprayer Upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by ssoulssurfer, Apr 5, 2018.
  1. Aug 25, 2018 at 5:20 PM
    #201
    1997tacomav6
    Denver
    Nope
    ThunderOne[QUOTED] likes this.
  2. Aug 26, 2018 at 9:01 PM
    #202
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You may have a loose connection on a hose or hose damage somewhere allowing air in. :notsure:
  3. Aug 27, 2018 at 6:51 AM
    #203
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I haven't done the mod yet. But I've had trouble with other cheaper nozzles doing that
  4. Aug 27, 2018 at 9:57 AM
    #204
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    Any feedback? I have two in my Amazon cart rt now, waiting to order.
    I want to replace the hose from the tank to the nozzles to, do you have a link or hose size?
    Thanks
  5. Aug 27, 2018 at 9:57 AM
    #205
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    No. All fluid goes in nice "fan pattern" to the windshield. I don't know what was the problem before I installed Odyssey nozzles, but it felt like fluid was backing up after some time - it took few seconds of fluid pump running before the fluid start out of the nozzle. After installing Odyssey nozzles, the fluid starts spraying without delay. :notsure:
    I aimed the spray at the the upper part of the windshield (about 2/3) while stationary and the god thing the spray stays at the same place also while running at 55mph (I had no chance to drive at higher speeds yet). So overall this mod while not relatively cheap (26 dollars for sprayers) is one of the best for the money - I rate it the same as Redline Tuning hood lift.
    ChinoXL, SwampYota and Bulldogs129 like this.
  6. Aug 27, 2018 at 10:04 AM
    #206
    Madjik_Man
    Colorado Front Range
  7. Aug 27, 2018 at 10:45 AM
    #207
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I did this yesterday. Mine leaves a small puddles in front of the nozzles when done. I may try new lines. But otherwise they work well.
  8. Aug 27, 2018 at 12:32 PM
    #208
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Same. I can live with it.
  9. Oct 10, 2018 at 1:58 PM
    #209
    1997tacomav6
    Denver
    So snow is already here yesterday and today coming down strong.
    This is the first work out these Honda nozzels have been put to use.
    They pass with flying colors.
    At 70 mph they hit the center of the windshield perfectly and standing still too.
    What a great mod :)
    Bulldogs129, MacGyvR and SwampYota like this.
  10. Oct 10, 2018 at 2:22 PM
    #210
    RysiuM
    Rysiu
    Second that. In my truck the side effect was that the washer fluid does not back up anymore. It was strange that with original factory nozzles I had to pull the washer switch for a good second before the spray started (with wipers scraping dry windshield). With Honda nozzles the spray is instant.
  11. Oct 10, 2018 at 3:05 PM
    #211
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    I noticed that as well. The spray is almost instant with the newer nozzles vs the stock ones.
    Has anyone else noticed if it's making their windshields dirtier where the wiper blades don't reach? Like in the middle near the bottom or the upper corners.
    Still getting fluid on the side windows too if I spray while driving. I'll see if I can get some pictures later.
    EDIT:
    Also getting the puddles on the hood that others are seeing. But the spray coverage is worth it.
  12. Oct 10, 2018 at 4:07 PM
    #212
    Bulldogs129
    Malcolm
    Mississippi
    Nothing’s better than in the field testing.
    Ours are working great in 95-100 F temps
  13. Dec 1, 2018 at 2:16 AM
    #213
    NBTaco
    NBTaco Member
    Edmundston
    09 TRD Sport
    Lately I noticed that the spray coming out of the nozzles of my 2009 Tacoma is really weak and anemic. I read all through this threads and did the air pressure clean to all the rubber parts, removed the nozzles and soaked them in CLR... but no avail... still very weak.
    I would like to try the Honda Odyssey 76810-TK8-A01 As they seem to do a great job on a 1st gen... My question is will they fit on a second gen Tacoma?
    Thanks in advance for your replies!
  14. Dec 1, 2018 at 8:48 AM
    #214
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Not that particular model but a similar one with the hose barb towards the back would. Like this.
    Just remove your sprayers to confirm the hose barb orientation.
  15. Dec 1, 2018 at 12:16 PM
    #215
    NBTaco
    NBTaco Member
    Edmundston
    09 TRD Sport
    Thank you se7enine , the barb is oriented towards the back. So the one in the pick should fit? Will I need to do any modifications or is it plug and play?
    Thanks again! Very appreciated!
  16. Dec 2, 2018 at 2:43 PM
    #216
    cyriouslydylan
    cyriouslydylan Active Member
    Just want to thank you guys for this thread, especially se7enine for doing all that testing and video. I recently broke one of mine while removing the hose to try and clear a clog, and I picked up these guys off Amazon for like 21.50 for the pair. I had to replace the reservoir as well, and all new tubes coming in with that, will update with how it works when I get them in!
    1997tacomav6 likes this.
  17. Dec 2, 2018 at 4:19 PM
    #217
    NBTaco
    NBTaco Member
    Edmundston
    09 TRD Sport
    Cyrioulydylan, your link doesn't show the nozzles... do you drive a first gen, second or third gen tacoma. I have a second gen and my original nozzles are not working properly... just hope to find a good replacement...
    Why did you have to change the reservoir and hoses?
  18. Dec 2, 2018 at 4:21 PM
    #218
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    He probably drives a first gen since this is in the first gen section. You may have better luck in the 2nd gen section
  19. Dec 2, 2018 at 4:35 PM
    #219
    cyriouslydylan
    Yes a first gen. I had to change the reservior because the upper part of it, sort of the funnel bit broke into a million pieces, and some bits got into the pump and hoses and nothing worked anymore:
    I couldn't pass inspection in my state without the wiper fluid working, so I had to replace pretty much all of it. Unfortunately no junkyards in my area had the correct reservoir, but I found a new one with a pump for around $60.
  20. Dec 2, 2018 at 4:51 PM
    #220
    NBTaco
    NBTaco Member
    Edmundston
    09 TRD Sport
    Thanks for the info..
    And yes I started a new thread in the second gen section with no replies...
    Seems like I'm the only second gen owner with crappy nozzles in North America... ?
    I had more help here from se7enine and the info in generalon this thread ...
