Windshield Wiper Control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TSubatis, Feb 11, 2009.
  1. Feb 11, 2009 at 6:05 PM
    TSubatis
    TSubatis [OP] Well-Known Member
    Boston, MA
    2007 DC 4x4
    Billstein 5100s + Toytec TSB AAL, 17" Moto Metal Blacks, 275/85 Toyo Open Country A/T's, BHLM, Satoshi Grill, Sport Hood, Kenwood DNX5120, Kicker Speakers
    Hey everyone, I'm new to TW, not sure if this is posted in the right section...
    Anyways, I have a pretty standard, stripped down tacoma, not many bells and whistles... I was wondering if anyone knew where I could find a windshield wiper lever/control that allows me to control mist/slow speeds and higher speeds. Right now my wipers only have three options: a manual wipe (move lever up) fast (one click down on lever) and super fast (two clicks down on lever) I need more control, bottom line... Also, is the install on something like this complicated?
    Thanks
  2. Feb 11, 2009 at 6:07 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    look in the Buy/Sell/Trade for this item....
    and Welcome to TW!!
  3. Feb 11, 2009 at 6:59 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    You should be able to get them at the dealer, but I'd check ebay or the junkyard first.
  4. Feb 11, 2009 at 7:12 PM
    TSubatis
    Boston, MA
    2007 DC 4x4
  5. Feb 11, 2009 at 7:22 PM
    Lentsnh
    Do it! :D
  6. Feb 12, 2009 at 4:57 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Here's a link to the guide I put up in the Cheap/Free mods area.
    Intermittent wiper install
    It takes about 10 or 15 minutes. Let us know how it goes :D
  7. Feb 12, 2009 at 5:43 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    No star tool needed, just 113.00 shipped to ya & a phillips & something to pry apart the shell on the column. The stalk has one big clip to release the stalk facing you.
  8. Feb 24, 2009 at 7:04 PM
    sobx
    sobx Member
  9. Feb 24, 2009 at 7:57 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Try a salvage yard
  10. Feb 28, 2009 at 12:12 PM
    sobx
    sobx Member
  11. Feb 28, 2009 at 12:30 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    variable speed control? IIRC.......damn, not recalling correctly now which I went with, sorry.
  12. Feb 28, 2009 at 12:42 PM
    steelerfan7p
    steelerfan7p My other car is a Bugatti
    Yes
    Fairmont, WV (1 Hour South of the City of Champi
    Non-TRD, Non-SR5, Non- Prerunner
    Rear Leaf Spring TSB, Metra IPod Adapter, AFE Pro Dry S Air Filter, I was added to the truck to make it better, so does that count as a Mod?
    As I recall, it doesn't matter what the piece is for, only that it has that part number. It is the exact same part for several different models of Toyota including the '09's
  13. Mar 14, 2009 at 10:37 AM
    imkms
    imkms Member
    South Jersey
    09 Access 4x4 4.0
    Intermittent Wiper Spare Tire lock
    First, thanks for the great info (I am new to this site). I just purchased a new 09 Tacoma Access Cab 4x4 and it only has the 2 speed wiper control (there is not even an intermittent position) Does the 84652-04141 provide that piece as well or am I stuck with what I have. If so, are there instructions to replace it as well as replacing just the relay. Appreciate any advice
  14. Mar 14, 2009 at 12:55 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
  15. Mar 14, 2009 at 1:01 PM
    Rickochet
    Rickochet Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I have an '09 and used 84652-04141. Everything is built into the switch. It still does the "bump" swipe, two speeds and variable intermittent control and misting. Follow the install thread. Once you get the cowling off unclip and unplug the old switch and plug in the new one and slide it in the clip. The most trouble I had was wrestling the cowling off and on. But basically a pretty simple job. And once you get it on you will really appreciate it.
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods-11.html#post82545
  16. Feb 3, 2014 at 4:50 PM
    smokydogs
    smokydogs New Member
    FL
    Graybaby
    Hey, this is my first post to TW. This is a great site and I appreciate all the help from friendly folks here.
    I have basic extended cab 2010 Tacoma. I wasn't satisfied with the wiper controls and wanted and intermittent one. I learned from other posts on TW that there are two wiper stems which will work and replacing them for my old two speed stem would work and no wiring is needed. I got a used 84652-02610 off of ebay, installed it with a little help from TW users and, viola, it works like a charm. Now I understand that part no. 84652-04141 works just fine only the intermittent direction is opposite from the one I installed but, what the hey, it works in either direction.
    The installation is pretty straightforward but care should be made in first removing the modular side by side connectors attached to the stem, and then removing the stem. The reason is that the stem in place will help stabilize the part to help "unplug" the connector. The other thing to do is find the place to push to release the stem. It's right in the middle facing the driver. A flat-edge screwdriver should work nicely. DON'T ever force anything, just be gentle and nice and easy. You can do it. My backup plan is a friendly Toyota dealer service tech. They will always help when they see you already have the part because they want your business for the future.
    I do have one question about the new wiper stem: what does the mist function do? My wife has a Rav4 with a mist position but the users manual never mentions it. When I try to activate it on the stem all I get is a one swipe of the wipers and no mist. Am I doing something wrong? This also what happens on my wife's Rav4.
  17. Feb 3, 2014 at 4:55 PM
    Rickochet
    Rick
    Kentucky
    To get the swipe you bump the handle up. To get it to mist you pull it toward you. To do a quick window clean pull the lever toward you a time or two for some liquid then bump the handle up for a swipe. This is how it works on my Taco and my wife's Highlander.
    Welcome aboard.
    Rick
