Winter time tire pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pcledrew, Oct 25, 2010.
  1. Oct 25, 2010 at 10:16 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I keep the same pressure winter or summer. No problem with that.
  2. Oct 25, 2010 at 10:27 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
  3. Oct 25, 2010 at 10:45 PM
    AlerAero
    AlerAero Equipment MFG
    Northern Vermont
    09 Tacoma V6 SR5 4x4
    BakFlip Folding Tonneau, Locking bed storage compartments, Bug/rock guard, Anytime backup cam mod, Hitch + wiring
    Thats interesting. So Toyota's target tire pressure is 31.9 psi! Alot of funny math in this TSB I think only has to do with if your checking tire pressure in the heated garage in winter.
  4. Oct 26, 2010 at 4:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Caulk test is for every day driving. If you're going dropping your tire pressure for off-roading or winter driving, you're intentionally running lower than normal pressure in your tire and would (and should) fail the chaulk test.
  5. Oct 26, 2010 at 6:21 AM
    inouk
    inouk Well-Known Member
    I agree with you, but may I add something:
    On roads covered by snow, even 1ft or 2 ft, it's better to not float, handling is poor and you won't move forward as easily as a narrow and inflated tires.
    Narrow and inflated tires are better than large tires in snow, because they'll act like knives, they will go through snow to find the hard surface, the aspalt, to move on. That's why small cars seems to go forward easily, easier than 2WD trucks, because they have small and narrower tires, even they're low quality winter tires (FWD helps too).
    Sand, like driving on beaches, is another story, you don't have a hard surface below, so the only option is to have large tires and flatten them out. However, if you do offroading on snow, that's another story... In this case, get a snowmobile! :)
    So, my tires are inflated to 35psi all seasons and winter tires are a little narrower (Blizzak DM-V1 245/75/16) than summer tires (Michelin M/S LTX 265/70/16).
