Winter Tires.
Discussion in 'Wheels & Tires' started by SNOWTRD, Oct 17, 2015.
  1. Oct 18, 2015 at 2:20 PM
    #81
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  2. Oct 18, 2015 at 2:21 PM
    #82
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Have an open mind. The practicality of changing two tires at a slower rate then you change one is I rrefutable That is the simplest way of putting it. But then, we so called fuzzy math people will pay more money for insulation then trying to buy the cheapest heating fuel by burning wood. It's called saving money by looking at all the competing factors.
    nv529 likes this.
  3. Oct 18, 2015 at 2:33 PM
    #83
    blens
    blens Well-Known Member
    British Columbia
    Blazing Blue 2016 TRD Sport Upgrade 6MT Tacoma
    I've had great luck with Michelin X-Ice on my Subaru, just put Hankook RW11s on my 2016 though, haven't had any snow to test them out yet though.
  4. Oct 18, 2015 at 2:51 PM
    #84
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I have used studded Altimax tires for a few years and I have not noticed any difference in dry or wet other than road noise compared to non studded Altimax that I have also tried in the past.
    Here is a great link from tire rack testing tires. Video explains it well too. While there wasnt much difference in snow traction, there was a good improvement in ice traction with studs and about a 5% reduction in dry emergency braking with studded tires, which to me isn't significant enough to worry about.
    http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=123
    DoorDing likes this.
  5. Oct 18, 2015 at 2:57 PM
    #85
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    You may not until you do an emergency maneuver. Seldom do the people left standing have an issue with anything. If they are making road noise, you know imediately that the contact surface differers when hitting the pavement. Then, you have to decide for yourself if metal vs rubber on pavement increases or decreases stopping distance.
  6. Oct 18, 2015 at 3:45 PM
    #86
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    If you look at the individual catagories of performance of the various tires on Tire Rack tests, for deep snow, light snow and ice, there is not much difference in performance between the better/ best and several other less expensive brands. Yet, for a set of four, you can pay hundreds of dollars difference. Cheaper snow tires perform as well in snow and on ice if you can take things like, higher noise on dry pavement. If it's a difference that you can accept with a truck you can save money and still be safe.
    Ultra Grip, Altimax and even Winter force have very acceptable and often, superior winter performance and used in a truck, you can save lots.
  7. Oct 18, 2015 at 4:54 PM
    #87
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Looks great :thumbsup:
  8. Oct 18, 2015 at 5:55 PM
    #88
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Exactly. The one ton 4 wd plow truck with a sander on back that I used had LT versions of the Firestone Winterforce tires. They are noisy, don't handle real well on pavement bit are every bit as good as other LT snow tires that were much more expensive. Seeing that we seldom got more them two years out of even the best snow tires, economizing is good......or I got paid less. We were hard on them because they went on very early and stand on very late....when it was warmer. Had to stay prepare for unanticipated storms.
  9. Nov 3, 2015 at 6:40 AM
    #89
    greengs
    AB, Canada
    Here's a more recent test.
    http://tekniikanmaailma.fi/winter-tyres-2016
    Studded tyres
    BridgestoneBlizzak Spike-01
    ContinentalIceContact 2
    DunlopIce Touch
    GislavedNord Frost 100
    GoodyearUltragrip Ice Arctic
    HankookWinter I*Pike RS
    LinglongGreen Max Winter Grip
    MichelinX-Ice North 3
    NokianHakkapeliitta 8
    Nordman5
    PirelliIce Zero
    SavaEskimo Stud
    Non-studded tyres
    BridgestoneBlizzak WS80
    ContinentalContiVikingContact 6
    GoodyearUltra Grip Ice2
    MichelinX-Ice XI3
    NankangIce Activa Ice-1
    NokianHakkapeliitta R2
    NordmanRS
    PirelliIce Zero R
    Blue=Studded tire
    Orange=Studdless
  10. Nov 3, 2015 at 9:44 AM
    #90
    Aspie83
    Aspie83 Well-Known Member
    2016 OR AC MGM
    This makes a lot of sense. I would only add that when buying tires look at the manufacture date. The rubber ages whether being used or not, and deep cracks can form in rubber that is older than six years.
  11. Nov 3, 2015 at 10:40 AM
    #91
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Good idea.......
    Other thoughts.....Quite obviously it is not worth letting tires sit for a long time but an average of 15 -20 k per year easily means you replace the tires well before that happens. That is 45 to 60 k on each set within that time. Storing tires inside out of the sunlight when not used and they age slower then those on the car. Tires DO age faster when subjected to elements while on the car and sitting faster then when in appropriate stowage. It's not running cars but with weight on them too that accelerates aging. You will see on trailer tires, the cracking starts on the bottom were the tire bulges during storage. Hopefully, you store the unused tires inside and not supporting weight. Still, that is an excellent suggestion to check dates before you buy tires used this way........
    Aspie83[QUOTED] likes this.
  12. Nov 3, 2015 at 11:11 AM
    #92
    Splat
    Splat Well-Known Member
    Pat
    MTL, Quebec
    2016 Black DCLB TRD Sport
    In progress...
    Got those Nokian installed this morning. Got them a bit bigger (265 70/17) and they fit perfect. No complaint on my way back home. For some reason the bigger size is actually cheaper.
  13. Nov 3, 2015 at 11:15 AM
    #93
    AZInferno
    AZInferno Well-Known Member
    2016 TRD Sport Inferno
    My winter tires are my summer tires, it never snows in Phoenix! :thumbsup:
    Dagosa likes this.
  14. Nov 3, 2015 at 11:23 AM
    #94
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Hankook Dynapro ATM
  15. Nov 3, 2015 at 11:23 AM
    #95
    WarrenG
    WarrenG Well-Known Member
    Check out canadian tire. The motomaster total terrain WT, get them studded and you will be happy. Great tire made in north america and price is hard to beat. Some stores wont stud so confirm before purchase. We sled in Rocky Mountains so I speak from experience.
    BC Hunter likes this.
  16. Nov 3, 2015 at 12:32 PM
    #96
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    I wouLd up size my snows or regular in a heart beat except for two problems. First, I cut down the room for snow and slush to collect, secondLy, everything including the spare needs to be up sized as well just in case a flat is on the rear or you need 4 wd
  17. Nov 3, 2015 at 1:50 PM
    #97
    Aspie83
    2016 OR AC MGM
    I got the Nokian R2, which consumer reports rated highest of those they tested. But isn't there supposed to be a snowflake symbol on all winter tires? I can't find one on these.
  18. Nov 3, 2015 at 2:16 PM
    #98
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    Nokian Hakkapeliitta LT
    Fye123 likes this.
  19. Nov 3, 2015 at 3:17 PM
    #99
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    I also see one, as he said just after M+S
  20. Nov 3, 2015 at 3:17 PM
    #100
    Aspie83
    2016 OR AC MGM
    Thanks for the picture and pointing that out. Tomorrow when it's light I'll confirm that on mine.
