wiper squeek
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mordeeb, Sep 2, 2021.
  1. Sep 2, 2021 at 6:59 AM
    mordeeb
    mordeeb [OP] Active Member
    2016 TRD Sport
    Have a 2016 and I thought this was just the blade going bad so I replaced it and cleaned the windshield. No go. I then turned the wipers on with the blades off the window in the up position and the loud squeak still happens. I sprayed some WD40 into the area where the wiper nut is and around it after cleaning out everything around it but still a very loud squeak! Any ideas what else to do? This noise is extremely loud and awful when using the wipers.
  2. Sep 2, 2021 at 7:04 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    First try cleaning the windshield. Use a razor blade or steel wool and glass cleaner. If that doesn’t work you can try some rain x or very light coat of wax on the windshield and see if it improves.
    RedWings44 likes this.
  3. Sep 2, 2021 at 7:06 AM
    mordeeb
    2016 TRD Sport
    It’s making the noise when the blade is up, the wipers aren’t even touching it’s all coming from the mechanism itself.
  4. Sep 2, 2021 at 7:14 AM
    Tacospike
    Two Trucks
  5. Sep 2, 2021 at 7:15 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    There are bushings in the wiper transmission that need to be greased. As stated, white lithium grease has worked best for me too. Transmission sits under the cowl panel.
    Tacospike likes this.
  6. Sep 2, 2021 at 7:22 AM
    mordeeb
    2016 TRD Sport
    how hard is it to get to those bushings?
  7. Sep 2, 2021 at 8:06 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Might have to pull the cowl and check the linkage
  8. Sep 2, 2021 at 8:27 AM
    mordeeb
    2016 TRD Sport
    so popped the cowl off on the driver side and sprayed the heck out of all the moving parts where the sound seems to be coming from still nothing. Had the wiper blades off entirely to get down there.
  9. Sep 2, 2021 at 11:33 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Getting near friday
  10. Sep 2, 2021 at 12:07 PM
    mordeeb
    2016 TRD Sport
  11. Sep 2, 2021 at 2:25 PM
    zoo truck
    None
    Well if its just a squeak and not gouging into the windshield i wouldn't complain....unless its friday already
  12. Sep 2, 2021 at 7:53 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    Wiper blade squeak comes from incorrect-poor contact pressure between the wiper and the glass.
    Did you just replace the wiper insert or the whole blade assembly? If you replaced just the wiper insert I would suggest replacing the complete wiper blade assembly.
  13. Sep 3, 2021 at 8:35 AM
    mordeeb
    2016 TRD Sport
    so after wd40 must have done it's magic on the moving parts under the cowl the noise is now gone.
    rsimi72 likes this.
