Wire extraction / Insertion tool for Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Janster, Sep 23, 2013.
  1. Sep 23, 2013 at 12:06 PM
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    Does anyone know the wire extraction / insertion tool that Toyota uses? Particularly the climate control harness/small plug? Do they use the same extraction tool across the entire platform?
    As seen in this thread:
    http://www.tacomaworld.com/forum/2n...climate-control-pod-burnt-connection-fyi.html
    Also, on the small plug, the type of female crimp?
    Not needed yet (knock on wood) but it may be necessary to repair this connection soon before it shorts out again. My husband works in electronics and can easily repair these things if he has the right tools & parts.
    I tried calling two different dealers and they refuse to give information. They refer you to a Toyota website that you have to subscribe to. :rolleyes:
    https://techinfo.toyota.com/
    Other searches I've done...people using typical picks/screwdrivers.... but I'd rather not make this a hack job. THANKS!
  2. Sep 23, 2013 at 1:56 PM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Go here:
    http://www.scribd.com/doc/11192307/Toyota-Wire-Harness-Repair
    Look at page 11. It appears you have to make one tool, and there's also a special service tool you can get.
    These folks might be able to help you get the SST mentioned:
    http://www.handsontools.com/OTC-Tools-09991-00500-01-Remover-ECU-Pin-_p_50701.html
    Otherwise, a dental pick is a perfectly acceptable tool to use for something like this. It's really my go-to tool for unpinning connectors like this. A little care, and you won't mangle anything.
