Wireless Apple Car Play
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MBCardsfan1982, Dec 21, 2022.
  1. Feb 3, 2023 at 10:10 AM
    #81
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Not plugging in. Such a minor thing so much enjoyed. I love the wireless CarPlay.
  2. Feb 3, 2023 at 11:21 AM
    #82
    JerTaw
    JerTaw Well-Known Member
    Jeremy
    Seattle
    2021 TRD OR DCSB
    Surprised there is a sound quality hit, I would have assumed it's all digital via carplay anyway, but you found it noticeable?
  3. Feb 3, 2023 at 12:26 PM
    #83
    JTScribe52
    JTScribe52 Well-Known Member
    Dan
    2018 SR5
    I understand that aspect, but is it really CarPlay without the interface?
  4. Feb 3, 2023 at 12:35 PM
    #84
    bockafer
    bockafer Well-Known Member
    Earth
    22 Limited 4x4 MGM
    You do get the interface, it still does screen projection.
  5. Feb 3, 2023 at 12:41 PM
    #85
    JTScribe52
    Dan
    2018 SR5
    REALLY. Hmm.
    So, just to confirm my understanding, instead of looking like this:
    You get this, right?
  6. Feb 3, 2023 at 12:44 PM
    #86
    MTBTACORN
    MTBTACORN Well-Known Member
    Ontario, Canada
    23 Tacoma TRD Pro 21 Sportster S
    You can listen to the radio (FM/Sirius) through the Entune Interface and still have the Apple CarPlay up for everything else. Just set the station then click the home button and choose Apple CarPlay.
    bigsmirt likes this.
  7. Feb 3, 2023 at 12:45 PM
    #87
    bockafer
    Earth
    22 Limited 4x4 MGM
    Yes, it is just like normal CarPlay/AA without having to physically plug in. It requires your phone to support wireless CarPlay/AA. Some AA wireless adapters are really carplay on the car side of the connection. I've had good luck with the Motorola MA1 for my Android Auto.
  8. Feb 3, 2023 at 12:46 PM
    #88
    JTScribe52
    Dan
    2018 SR5
    OK, I think that's where my confusion is coming from. This is for head units with factory CarPlay only, per the Amazon listings. It does not add CarPlay where it did not already exist.
    TacoTime55 likes this.
  9. Feb 3, 2023 at 12:51 PM
    #89
    MTBTACORN
    Ontario, Canada
    Correct. The dongle just allows you to use CarPlay wirelessly instead of having a cord plugged in to your phone.
  10. Feb 3, 2023 at 1:18 PM
    #90
    anamorphic
    anamorphic Well-Known Member
    08 TRD Sport 4x4
    chiming in on this- I definitely noticed sound quality taking a hit. I was really surprised by this as it really doesn’t make much sense to me why this is happening.
  11. Feb 8, 2023 at 6:48 PM
    #91
    MTBTACORN
    Ontario, Canada
    It arrived today. I installed it tonight before leaving for work so I don't have much use with it so far but it connects in less time than it took my phone to connect via cable. Had it do some Siri commands and all worked very well. Made one phone call and had no issues. It connected very quickly after a stop at the store. No complaints so far.
  12. Feb 14, 2023 at 7:17 AM
    #92
    MTBTACORN
    Ontario, Canada
    It has worked well for the past 6 days that I've had it. I don't notice much of a sound quality difference, if any. I do find it lags slightly when I skip to the next song with the steering wheel controls at times. Other than that, I'm pretty happy with it.
    82nd_Devil likes this.
  13. Feb 15, 2023 at 11:59 AM
    #93
    unclewede
    unclewede Well-Known Member
    'Nard
    23 TRD Sport 4x4 Lunar
    I was SO glad when I got my Taco and it was wired. Wife had an X3 for about a year, no cable at all. The raging scream-fests that we regularly had because a) I'm a computer geek by profession and b) I couldn't make her phone and BMW talk reliably.
    For the BMW, you had to use their internal wi-fi after the BT connection. Well, it wasn't very good. So a map display just didn't get enough info, and songs skipped all the time. Phone calls dropped about 50% of the time.
    As long as I can, I will always use a wire for CarPlay.
    faawrenchbndr likes this.
  14. May 6, 2023 at 8:50 AM
    #94
    Way Way Afar
    Way Way Afar Well-Known Member
    2022 TRD OR 4x4 DCSB AT
    I'm currently using the CarlinKit 3.0. A couple of days ago I checked and found a new software update. After it was complete I looked at the settings and found two surprises.
    1. I've never noticed before but it shows a GPS location on/off setting. I'm not giving that data to anyone so it's now turned off and so far everything still works as before.
    2. Also found a media delay setting. While watching a video there is an annoying delay between the audio and the person talking. The default setting for me was 1000MS. I was able to get it down to 300MS which helps a lot. Curious if anyone is able to get a lower delay number to work.
    Edit: It's only been a few days but I've yet to have the dongle not connect to the phone. Typically I have to reset the connector every 5 - 6 times to get the connection to happen.
  15. May 6, 2023 at 11:19 AM
    #95
    B1gDaddyT
    B1gDaddyT Well-Known Member
    2019 Cement Taco TRD OR 4x4 DCSB
    I'm curious on the call quality options - would someone not want clear calls? :boink:
  16. May 6, 2023 at 11:26 AM
    #96
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    I’m not so sure about the value of Apple Car Play, so going wireless is not my goal. Last week I was out of cellphone coverage and Apple Car Play was unable to give directions. The built-in navigation worked fine and got me back to civilization.
  17. May 6, 2023 at 11:35 AM
    #97
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I haven't done any updates on our CarLink3.0 since install more than a couple months ago.
    We used it while in Canada headed to Toronto in early April...worked fine once we figured out we had to activate international roaming on our Mint Mobile account.
