Wires Through The Firewall - The Right Way!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunn_runner, Feb 1, 2018.
  1. Feb 1, 2018 at 8:33 AM
    gunn_runner
    gunn_runner [OP] www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Kind of an arrogant thread title, right? I mean, who am I to judge!? Regardless, I was looking for a clean way to push an expanding bundle of wires through the firewall without stabbing holes through the existing rubber boot. Why am I against this easy method? Punching a single hole in the OEM boot works fine, but as your wiring needs grow, so do the random holes in the boot.
    The Daystar Firewall Boot:
    Harbor Freight Stepped Bit:
    I purchased the Daystar Firewall Boot for around $16, and a from Harbor freight. There's a great spot above the OEM rubber boot, just to its 1 o'clock if you're looking at it head on from the engine bay.
    1" hole drilled. You can go up to 1 1/4" for the boot:
    Drill a small pilot hole, then use the large stepped bit to open the hole up to any size between 1" and 1 1/4". The only thing behind this spot is some loose carpeting. I popped the bare metal around the hole with some Rustoleum.
    Daystar Boot installed and ready for more wiring:
    The good thing about the Daystar boot is that you can cut away the stepped rubber as your wiring increases, and just ziptie it closed to prevent any water from entering (if you're the stream crossing type). I hope this helps you 2nd gen owners. Not sure if the firewall location is the same on a 3rd gen, but I'm sure the Daystar boot can be made to work.
    Now it's time to get wiring!
  2. Feb 1, 2018 at 8:40 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Kudos to you sir, nice find, good job!
    gunn_runner[OP] and ChadsPride like this.
  3. Feb 1, 2018 at 8:42 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Cool setup!!! I may do this with the massive harness I'm about to make.
  4. Feb 1, 2018 at 8:46 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    But this takes all of the "FU-n" out of trying to yank a switchpro plug, wiring and loom through a tiny slit in the side of the oem boot!
  5. Feb 1, 2018 at 8:48 AM
    DrFunker
    DrFunker Well-Known Member
    Terrific! :thumbsup:
    Thanks. :hattip:
  6. Feb 1, 2018 at 9:09 AM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    I can only imagine... that boot is a PIA!
    ChadsPride likes this.
  7. Feb 1, 2018 at 9:18 AM
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    Wish I would've seen this like 2 years ago. :facepalm:
  8. Feb 1, 2018 at 9:32 AM
    Gunshot-6A
    Conner
    Everett, WA
    It is actually pretty easy if you make a decent size slit with a pocket knife, run a straightened coathanger up from inside the cab, use a long screw driver to pry the grommet open a little more, and yard the cable in question through. Just takes a little time to get the "technique" down.
    vicali and DarkMark340 like this.
  9. Feb 1, 2018 at 9:46 AM
    badger
    badger Well-Known Member
    07 SR5
    Nice tip, thank you. I've jammed my last wire through the existing pass throughs. They are packed !
    HillJackJDS, outxider and ChadsPride like this.
  10. Feb 1, 2018 at 9:54 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I might eventually have to do this also. Il tired of poking holes in the main firewall boot, my 1 small grommet on driver side is full, my 2nd small grommet on pass side can only take a few more 12awg wires. And I don’t want to run shit down to the grommets that are under the seats.
    I’m debating between a blue sea clamshell setup or the daystar boot. The only advantage to the clamshell is it makes running new wires through the same passthru a little more easier. But you have to do 1 big hole and 5 small holes instead of 1.
  11. Feb 1, 2018 at 9:59 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Great write up!! For those who have already cut plumbers putty makes great sealent also won't harden like silicone.
  12. Feb 1, 2018 at 10:00 AM
    Sandyman
    Sandyman Well-Known Member
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
  13. Feb 1, 2018 at 10:19 AM
    gsxrdoug
    gsxrdoug 2009 X-Runner
    Douglas
    Hawaii
    2009 X-Runner
    Stock
    Thank you.
  14. Feb 1, 2018 at 11:03 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Dang, my trusty wire clothes hanger can be retired I guess.
  15. Feb 1, 2018 at 11:40 AM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Ha! Yep, it's the last OEM crap in that line! But they'll stay for now.
  16. Feb 1, 2018 at 11:48 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Well shit.. I could have used this years ago....
    Awesome find OP!
  17. Feb 1, 2018 at 12:04 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    the "right way" would have been to debur that hole you drilled :p
  18. Feb 1, 2018 at 1:23 PM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    De-burred like a boss! :spy:
  19. Feb 1, 2018 at 1:28 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I did something similar, but maybe a little cheaper. I drilled the hole in the same area with a hole saw, deburred it of course. Put a rubber grommet in the hole. Passed all my wife's through. Then sealed with plumbers putty on both sides. I've done this to a few vehicles with no complaints of leaks. Mine hasn't leaked either.
    MolonLabeTaco and ChadsPride like this.
  20. Jun 4, 2018 at 8:01 AM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Nice! Perfect timing! I have a few more wires to run! :cheers:
    gunn_runner[OP] and outxider like this.
