Wires Through The Firewall - The Right Way!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunn_runner, Feb 1, 2018.
  1. Jun 10, 2018 at 7:37 PM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Thanks again man! Project done today!
    (Pardon the ugly grey paint...just a little primer)
    gunn_runner[OP] likes this.
  2. Jun 11, 2018 at 8:22 PM
    gunn_runner
    gunn_runner [OP] www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Hell yea! Glad it worked out for you.
  3. Jun 12, 2018 at 6:53 AM
    brucehutchinson
    brucehutchinson Active Member
    TX
    14 Tacoma TRD Offroad 4x4
    What size rubber grommets were these on your pelfreybilt fuse panel?
  4. Jun 12, 2018 at 7:03 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    ordered one
  5. Jun 12, 2018 at 3:02 PM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    I'm embarrassed to say that I just eyeballed it at the hardware store!
  6. Jun 12, 2018 at 3:05 PM
    brucehutchinson
    TX
    Yeah, I did the same but I get the thickness wrong.
  7. Jul 7, 2018 at 11:36 AM
    09BLk_Taco
    09BLk_Taco Member
    Flagstaff, AZ
    2009 Black Tacoma Double Cab SR5 4x4
    3 inch Toytec suspension lift with Bilstein 5100 shocks, Toytec front lift springs, and 1-1/2 Toytec AAL springs in back. 285/75R16 BFG KO2 All-Terrain tires, Cab Mount Chop, SPC Adjustable Upper Control Arms, LED lights in bed.
    This is awesome! just ordered firewall boot and stepped drill bit off Amazon and will be here today! Planning on using this to wire a subwoofer amplifier and some lights!
  8. Jul 7, 2018 at 3:35 PM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    That's what I have running through as well. And a CB and UHF radio!
    09BLk_Taco[QUOTED] likes this.
  9. Jul 8, 2018 at 9:09 PM
    09BLk_Taco
    09BLk_Taco Member
    Flagstaff, AZ
    Just Installed this with some wiring today, but I did it a bit differently than how you did in your picture. I flipped the rubber boot around so that the small end is inside the cab of the truck and the widest part of the boot is flush with the firewall on the side of the engine bay. I think this gives the job a cleaner look and looks more like the factory boot that has many other wires running through it.
  10. Jul 8, 2018 at 9:59 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I always cross streams ;)
    corgimas likes this.
  11. Sep 13, 2018 at 2:04 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Just did this today. I basically just drilled out an existing OEM grommet hole on the passenger side to 1.25” then put the grommet in. I had been using this hole for wires but now that it’s bigger I can run a lot more in the future if needed. All the stuff on my driver side is full and I’m not punching any more holes in the main firewall boot.
  12. Sep 13, 2018 at 2:44 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Very nice! Much admiration for your clean wiring. One of my first projects when I got Little Big Red was researching the install for the overheat thermometer - which turned into a GenTec autodim mirror, with the thermometer and compass. But I was pretty new to the site, and did not know past wiring through that main boot from what I had read at that point.
    20171111_134548.jpg Not wanting to drill a hole; since I know nothing of what might be on the other side. The trusty coat hanger is prepped!
    20171111_134608.jpg Surprise to me, it did not want to go through where the wires are. So, I routed it with the hood release cable. Nothing in the way, and only 2 #18 in a shroud.
    20171111_134819.jpg I just brought the whole thing thru the access hole without an issue.
    20171111_134830.jpg I had to put two Tyco connectors on the inside end. But it all worked out fine for two wires.
    No plans that would need that cool boot at this time, but now I know! Thanks.
  13. Sep 14, 2018 at 12:34 PM
    96carboard
    96carboard Well-Known Member
    I still favor the coat hanger through the factory boot approach, since drilling the firewall means that you have a new point where rust will start growing. And you might as well leave it completely bare for all the help that rustoleum will do.
  14. Sep 14, 2018 at 2:51 PM
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Believe me, theres zero chance that's going to rust unless you submerge your truck in ocean water! But thanks for the feedback...:thumbsup:
  15. Sep 17, 2018 at 10:42 AM
    #35
    96carboard
    Have you ever driven in the winter? Because that is effectively what winter driving is -- a CONTINUOUS bath in ocean (salted roads) water.
  16. Sep 17, 2018 at 11:30 AM
    #36
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Yes I live in Cleveland Ohio where the roads are saltier than the Dead Sea. There's no rust on the area I drilled, theres no moisture that gets to it. My frame is more likely to rot away before this small hole located at the top of the firewall poses a problem. Moving on.
    KTM753 and Flatliner like this.
  17. Sep 17, 2018 at 11:33 AM
    #37
    96carboard
    Give it some time.
  18. Feb 7, 2019 at 2:46 PM
    #38
    Sand Dog
    Sand Dog Well-Known Member
    2018 SR, 4x4 DCSB MGM
    JGO and Larzzzz like this.
  19. May 26, 2019 at 6:11 AM
    #39
    Moto_dj
    Moto_dj Well-Known Member
    Michigan
    2012 White Tacoma TRD
    Thanks for the tip!
    De-burred and painted
  20. Oct 10, 2020 at 5:22 PM
    #40
    looking
    looking Well-Known Member
    Doug
    Lancaster, Ohio
    2014 Sport DCLB 4x4 Barcelona Red
    Thanks!
