Wiring a mirror upgrade.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mytacoma01, Feb 19, 2022.
  1. Feb 19, 2022 at 6:56 AM
    Mytacoma01
    Mytacoma01 [OP] Well-Known Member
    Bob
    Hendersonville NC
    2014 charcoal gray SR5 double cab.
    So my son gave me this swanky Donnelly rear view mirror that has compass and temperature display. I ran the wires under the headliner and down the drivers side so that the reappear down by the E brake. According to the wiring directions, hooking them up requires a ground and a power connection only. I’m can hook the ground side up with no problem, it’s the power wire hook up that I question. Where would the best connection for the power wire be please? Be painfully specific please as that my knowledge of even basic auto electronic wiring is extremely obvious. :)
  2. Feb 19, 2022 at 9:29 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Do you currently have a factory overhead compass / temp display? That would be where I would splice into. I don't see how the temp would work without tapping into the ambient temp sensor unit. Can't be just power and ground.
    @caribe makaira
  3. Feb 19, 2022 at 9:43 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You will need to run temp sensor wires and add a temp sensor somewhere as well but most trucks have a factory plug behind the overhead console that has power and ground wires.
    If that plug is there the wire colors are:
    Red (Full Time Battery Power)
    Light Green (Ignition Power)
    White/Black (Ground)
    See also this thread.
  4. Feb 19, 2022 at 9:47 AM
    Mytacoma01
    Bob
    Hendersonville NC
    No I do not have a factory C/T mirror I’m starting from scratch. This mirror appears to have the sensor up where the mirror attaches to the windshield. When I acquired this mirror, my factory mirror was in place and this new mirror didn’t fit on the windshield adapter, it was too big. My son in law and I attached the wiring directly to the battery, outside of the truck to test it and the temp and compass were accurate. Since my windshield has been replaced I was able to choose an adapter that fits this mirror so I’m now ready to wire the new mirror.
  5. Feb 19, 2022 at 9:49 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    See if you have the factory plug (see my post above), if you do you have power and ground right there.
  6. Feb 19, 2022 at 10:11 AM
    Mytacoma01
    Bob
    Hendersonville NC
    I’ll check. Unfortunately I’m OOT at the moment for a funeral :( but will be able to get into it further tomorrow evening. Thanks for your input and I’ll be back to you in a day or so. :)
    Dm93 likes this.
  7. Feb 19, 2022 at 10:52 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    if its only a 2 wire hookup, its sounds like it has a builtin temp sensor which will only takes the inside cab temp. Not really a deal breaker and still an improvement in your no temp/ compass setup. I use the compass more than the temp to confirm I am not going the wrong direction on the freeway. lol.
  8. Feb 19, 2022 at 3:27 PM
    Mytacoma01
    Bob
    Hendersonville NC
    I see what your saying.
  9. Feb 19, 2022 at 3:32 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’d use acc power or ignition power.(this way it will only have power with the ignition in acc or if the ignition is on.) But I’ll tell I’m not a fan of splicing into factory wiring. Maybe use a tap a fuse.
  10. Feb 19, 2022 at 4:01 PM
    Mytacoma01
    Bob
    Hendersonville NC
    I understand what you’re recommending because of the selective power but again, how do I identify those wires down near the E brake where my wires come down?
  11. Feb 19, 2022 at 5:14 PM
    gotoman1969
    If you use a tap a fuse. You’ll go directly to the fuse box, the cover is marked as to which fuse is what.
