Wiring an aftermarket radio
Discussion in 'Audio & Video' started by cab4you26, Nov 20, 2012.
  1. Nov 20, 2012 at 8:45 AM
    cab4you26
    cab4you26 [OP] Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    I posted a thread in general automotive but didn't get much out of it, so mods feel free to delete or move either thread
    Anyway....I bought a jeep and the previous owner wired the radio straight to the battery with no fuse or anything. I don't know a lot about electronics, but how can I re-do the wiring to where it gets power when I cut the ignition on only? I guess I mean wire it like a stock radio.
  2. Nov 20, 2012 at 9:25 AM
    kevinsc
    kevinsc 2012 dbl cab 4x4
    kevin
    columbia, south carolina
    12 4x4 dbl cab
    chrome on front painted to match, satoshi grill done by myself, BHLM, billys all the way around with ome springs upfront and LR ucas with wheelers 3 leaf progressive pack in the rear, mb gunner wheels powdercoated black on 285/75r16 nitto trail grapplers, tinted all the way around and on windshield, pioneer dbl din touch screen with two 10's behing the seat and new speakers all the way around and certain interior parts painted to match, also have a road wire leather kit black with red stitching sitting here waiting for me to find time to install it!
    what year jeep? i can look up factory wires for 12v constant and also switched.. just let me know what year and i should be able to get you wire colors..
  3. Nov 20, 2012 at 9:32 AM
    cab4you26
    Corey
    VA
    The jeep is a 93 2 door sport
  4. Nov 20, 2012 at 10:29 AM
    kevinsc
    kevin
    12 4x4 dbl cab
    cherokee im guessing?
    if so red is constant (should be bigger then most of the other wires)
    and blue is switched (same size as most of the wires)
    both are in the ignition harness!
  5. Nov 21, 2012 at 4:31 AM
    cab4you26
    Corey
    VA
    Awesome, thanks. I'll check it out today.
  6. Nov 21, 2012 at 6:53 AM
    kevinsc
    kevin
    12 4x4 dbl cab
    no problem.. let me know how it goes
  7. Nov 21, 2012 at 1:55 PM
    cab4you26
    Corey
    VA
    I took the deck out, there is only one harness. Then he has a wire going to ground. From the deck there is a red wire and a yellow wire taped together and spliced with a white wire that goes straight to the battery.
    Also, if you know anything about the interior light i'd like to hear it. I checked under the hood for a fuse but nothing for it. There is a fuse block to the left of the steering column but nothing there to tell me which fuses go where. I can take a picture if it'd help. There are some wires going to nothing.
  8. Nov 23, 2012 at 8:50 AM
    kevinsc
    kevin
    12 4x4 dbl cab
    if they are together and going striaght to the battery you need to cut loose the red wire and run it to the ignition harness to the blue wire... on the aftermarket radio the yellow wire should be to the battery/ always have power and the red wire should be to the blue in the ignition harness or to the fuse box tap into a fuse that has power when the car is on but not when its off.. basically the red wire on the radio has power when the car is on but no power when the car is off ie makes the radio cut off when the car is off so it does not drain the battery..
  9. Nov 23, 2012 at 10:11 AM
    cab4you26
    Corey
    VA
    I looked up under the steering column, there is a rubber tube like thing containing wires that run up te column toward the ignition,horn, etc. I saw one blue wire out of like 20 and no red wire...
  10. Nov 23, 2012 at 12:02 PM
    kevinsc
    kevin
    12 4x4 dbl cab
    use the red wire from the aftermarket radio harness and run a wire from there to the blue wire that you found under the dash and just splice into it..
  11. Nov 23, 2012 at 12:09 PM
    cab4you26
    Corey
    VA
    I see, from what I understood you said there was a red wire and a blue wire coming from the ignition harness....where I only found a blue wire.
  12. Nov 23, 2012 at 12:11 PM
    cab4you26
    Corey
    VA
    The red and yellow wires spliced to the white wire went straight to the battery. The wire in the upper left corner went to ground. And then the others hooked to the factory harness.
  13. Nov 23, 2012 at 1:10 PM
    kevinsc
    kevin
    12 4x4 dbl cab
    easiest thing for you to do is where they yellow and red aretogether with the white... take the red wire off of that so that only the yellow is connected to the white.. then run a seperate wire sonnect it to the red and run it to the fuse box and tie it around a fuse that is a 10A fuse or 15A fuse and put the fuse back in the fuse holder... so you have any type of power tester like a meter? as it is now with the red and yellow on that white wire does the radio stay on all the time?
  14. Nov 23, 2012 at 1:14 PM
    cab4you26
    Corey
    VA
    I have a meter, but yes in it's current state I can use the radio without having the key in the ignition. Here is a picture of the fuse box under the dash:
    I don't know what any of the fuses are for because I don't have the cover for the box. The red wire connected to the 10a fuse goes to nothing. The hacked up white wire in the lower left corner runs up to the headlights I believe.
