Wiring bed lights.
Discussion in 'Lighting' started by euroshowoff, May 17, 2015.
  1. May 17, 2015 at 5:35 PM
    euroshowoff
    euroshowoff [OP] Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    I have lights that are sitting on top of my headache rack, whats the best way to route the wiring to the front into the engine bay?
  2. May 20, 2015 at 2:34 PM
    DarkZealot
    DarkZealot Name’s Barf
    Travis
    Huntington Beach, CA
    2015 DCLB 4x4 Taco
    Icon coilovers, Total Chaos UCA, OME Dakar springs, SCS F5 3.5bs Gunmetal wheels, 285/75/16 BFG T/A KO2
  3. May 20, 2015 at 2:38 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Depending on how your headache rack is made and where the lights are pics might help but drill a hole in the supports that run down the truck put the wires through that hole down through the bottom of the rack run them in between your bed and your cab and zip tie the wires to any harness underneath all the way to the battery:worthless:
  4. Mar 23, 2016 at 10:42 AM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Just run the wires down through the engine bay, along the frame and up to the bed? Is that what you recommend? Im wiring up some bed lights and am wondering how is cleanest and easiest way to do this
  5. Mar 23, 2016 at 10:46 AM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    BohlaaH likes this.
  6. Mar 23, 2016 at 12:22 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Yessir drilled out a tiny hole up by the bed rail to run the wire through and looks great cant see any wires or anything
  7. Mar 23, 2016 at 12:26 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    I might be doing this, just posted a thread on tapping into the trailer harness or something if there is steady 12V on a wire in the ass end. Your method seems easy enough.
  8. Mar 23, 2016 at 12:41 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    I think the whole process wired up and ready to go took me about an hour and that was more cleaning under the bed rails to make sure the lights would stick haha
