Wiring Harness Install question?
Discussion in 'Towing' started by jeepinoutwest, Dec 25, 2008.
  1. Dec 25, 2008 at 3:35 PM
    jeepinoutwest
    jeepinoutwest [OP] Well-Known Member
    Ok stupid question, I ordered a hopkins plug in 43355 wiring harness for my '08 reg cab 4 cylinder 2wd, but i can't seem to find where it plugs into. Did I order the wrong harness? Does anyone have a pick of where this attaches? Thanks for the help. rick
  2. Dec 25, 2008 at 3:40 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  3. Dec 25, 2008 at 4:20 PM
    jeepinoutwest
    I did check that out, but i cant seem to find the splice connection in the truck's rear end.
  4. Dec 25, 2008 at 8:11 PM
    jeepinoutwest
    Thanks, I didnt realize i had to pull the tail lights out in order to reach the T-connector. I mistakenly thought I would be able to see and access the connector from underneath the truck. Thanks guys.
  5. Dec 27, 2008 at 10:36 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Once you pull the tail light it is an easy install. Just be sure to leave enough length in the wires to the right tail light. I would not stick the converter onto the inside of the tail light until all wires are run. I had to pull mine loose and re-mount it lower to have enough slack to the right light.
  6. Dec 27, 2008 at 1:49 PM
    jeepinoutwest
    Thanks, i understand your advice perfectly. It will be very helpful. My harness gets delivered on tuesday.
