wiring Hella 500 lights and switch compatibility
Discussion in 'Lighting' started by Alex352, Dec 20, 2009.
  1. Dec 20, 2009 at 5:50 PM
    Alex352
    Alex352 [OP] Well-Known Member
    Alex
    Oregon
    07 Tacoma Dbl Cab
    http://www.tacomaworld.com/forum/2nd-gen-builds/281569-alex352s-build-thread.html
    hey guys i have 4 hella 500s that i want to wire and i want to bypass the high beam wiring so i can turn them on anytime. can this be done? If so does anyone have a diagram of the instructions?
    The switches that come with the hellas look kinda cheesy so i did some research and found some nice rocker switches on www.OTTRATTW.com. Does anyone know if these switches would fit in the empty aux slots to the left of the gauges? thanks in advance
  2. Dec 20, 2009 at 6:01 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I'm not sure if the switch would fit, Make sure the switch can handle the amp going through them
    Amp = watts/volts.
    4 lights is 220/12 = 18 amps.
    I used 10 gauge on all the wires.
    Wiring them is pretty much straight foward.
    A line from the battery to the relay
    a line from the battery to the switch to the relay to activate the relay
    one from the relay to a ground
    one from the relay to the lights.
    heres a half assed diagram i drew [​IMG]
  3. Dec 20, 2009 at 6:36 PM
    Alex352
    Alex
    Oregon
    07 Tacoma Dbl Cab
    Ok thanks. The size of the switch if .830x1.45 inches if that helps. im just in love with these switches.
  4. Dec 20, 2009 at 6:42 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    I'm not sure about the switch I got a first gen, I know 05 prerunner found some switches for his 2nd gen they fit in really well they are rocker switches as well.
    I'm not sure which rocker switch you're looking at there's a lot on there.
    Pm him
    http://www.tacomaworld.com/forum/members/05prerunner.html
  5. Dec 20, 2009 at 7:23 PM
    Alex352
    Alex
    Oregon
    07 Tacoma Dbl Cab
    ok thanks for all the help man I appreciate it. + rep
  6. Dec 21, 2009 at 8:24 AM
    another gsxr 1k
    another gsxr 1k Active Member
    Jax, Florida
    03 DCab PreRunner
    Tonneau cover, Fog and dual purpose backup / warning lights, tinted windows, stereo upgrade vent shades
    Yes, you can bypass the headlight side of the relay so you can turn them on at will. Install them as per the instructions from Hella with the exception of tapping into the headlight circuit. What you want to do is to tap into the cigarette lighter circuit. Once you do that, you can turn them on and off when you feel like it.
    Doing it that way will give you lights any time you want them and they will turn off when you shut the ignition off, so it won't kill your battery if you leave them on.
  7. Dec 21, 2009 at 10:14 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    x2
    I used the battery for my power though.
  8. Dec 21, 2009 at 4:18 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Just to be clear, the switch doesn't need to handle 18 amps or use 10 gauge wires. It just needs to handle enough current to activate the relay (which is minimal). That's the point of using the relay, so you don't have to run all that power through the switch.
  9. Dec 22, 2009 at 4:57 PM
    jward2331
    jward2331 Well-Known Member
    Fleming Island, Fl
    '08 PreRunner SR5 TRD Sport
    Debadged, tinted windows, upper/lower Grillcraft (horns relocated), Hella 500's with HID Mod (55W 5000) behind grill, shorty antenna, WeatherTech side window deflectors, suspension TSB, Westin Signature Nerf bars, JVC KD A-615 Head Unit with Sirius Direct tuner, Blacked out headlights, DTDL Mod (Switch for on/off), Hard Wired GPS, NOKYA Arctic Hyper Yellow Fog lights, Fog lights on anytime Mod, Michelin LTX M/S2 (P265/65R17), Powder coated OEM wheels. LED ANZO tail lights, Weather Tech FloorLiners.
