wiring help! is this safe???
Discussion in 'Lighting' started by kinkrider101, Mar 19, 2011.
  1. Mar 22, 2011 at 6:15 PM
    #61
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Alright, I'll hook you up to clear up any confusion. Remember, this is a reference...I take no responsibility for your actions.
    The red arrows represent the actual worst case current draw. I also labeled each wire as I understand it from your plans and descriptions. I'm also assuming that you aren't tapping power from a fog light or something inside the cab, so you'll have to run another wire from the battery. Typically you shouldn't do anything smaller than an 18 gauge wire for the relay control. Since this line is low current, a 5A fuse is readily available and sufficient for this line.
  2. Mar 22, 2011 at 8:14 PM
    #62
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Thanks!i got all the wiring done! I used all 10 and 12g wire with two 25a fuses and A relay
  3. Mar 23, 2011 at 5:15 PM
    #63
    larryde09
    Larry
    Boston, MA
    Just a reminder, if you're using a 25A fuse to protect a 12g wire, just be sure it's quality wire that can handle it.
  4. Mar 24, 2011 at 3:48 PM
    #64
    kinkrider101
    santa barbara
    wheels and tires
    I used the 25a fuses on the 10g wire
  5. Mar 25, 2011 at 6:10 PM
    #65
    kinkrider101
    santa barbara
    wheels and tires
    over build?
