Wiring Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LittleYoteTaco, Jun 27, 2024.
  1. Jun 27, 2024 at 9:30 PM
    LittleYoteTaco
    LittleYoteTaco [OP] Member
    2022 tacoma trd off road
    I previously posted about a wiring issue after trying to hardwire my new dashcam and got no response, but I have updates.
    It appears that anything connected to the fuse box under the cluster is not getting constant power (ie no door locking/unlocking, no dome lights, no hazards). None of this works while the truck is off. However, it works fine when the truck is in accessory mode, or powered on. All the fuses are testing good. I've exhausted my ability to get answers through Google and other means, as apparently I can't figure out the words to put in for the answer I need.
    Any insight is appreciated!
  2. Jun 27, 2024 at 10:00 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    It’s normal for a lot of cabin fuses be on accessory only power. Do you WANT constant power to it? You want it running power when the truck is off draining battery?
    I read your first post. Did you put an add a fuse in a blank space….?
  3. Jun 28, 2024 at 6:55 AM
    LittleYoteTaco
    No, I had used the sunroof fuse previously. I don't need constant power the fuses. The problem is, all things that box controls do not work when the truck is powered off. Like I can't lock/unlock my doors without using the physical emergency key, dome lights don't work, can't use emergency flashers, etc. So there's a wiring issue I need to locate, but I'm unsure what I'm looking for. I hope that makes more sense.
  4. Jun 28, 2024 at 7:43 AM
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    Pretty sure hazard lights work without the truck being on... Might want to check that.
  5. Jun 28, 2024 at 7:48 AM
    LittleYoteTaco
    ...... I did check that, which is why I said they didn't.
  6. Jun 28, 2024 at 7:53 AM
    CementHead18
    Jim
    SC
    Then you have another problem going on. Emergency flashers work without your truck being turned to "accessory" or with the key to "on/run".
  7. Jun 28, 2024 at 8:00 AM
    LittleYoteTaco
    I understand that, my entire post is asking for insight on where the problem may be. As I previously stated, everything that should work with the power off doesn't, and it's all connected to the fuse box under the dash. The fuses themselves are testing as good, I don't understand the wiring beyond that enough to figure out the issue.
  8. Jun 28, 2024 at 8:06 AM
    CementHead18
    Jim
    SC
    Gotcha'... That is pretty weird that they're working with the truck on "acc" or "on/run" and not with truck off. Maybe computer/circuit board related? Going to have to look at the wiring diagram to see what it might be.
  9. Jun 28, 2024 at 8:11 AM
    Clearwater Bill
    Billy
    Largo Florida
  10. Jun 28, 2024 at 10:42 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I don't have time to look at wiring diagrams right now but I can when I get home, my hunch would be that one of the ECU-B fuses is blown.
    What were you trying to tap your dashcam into?
  11. Jun 28, 2024 at 1:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I'm finally home. But I got to get washed off.
    Been running a string trimmer most of the day. I spent, and soaked in sweat.
    It will be a bit before I can take a look.
  12. Jun 28, 2024 at 1:43 PM
    TnShooter
    Deogee
    STOCK
    Lets start with the Dome Circuit.
    Check this fuses first
    10A ECU–B NO. 3
    7. 5A ECU–ACC
    7. 5A ECU–IG NO. 2
    5A AM1
    Check power to both sides of fuse.
    Key on and off.
  13. Aug 12, 2024 at 6:16 PM
    BSK
    BSK Keyboard not responding. Press any key to continue
    Trabant 501 Kombi
    Cigarette Lighter Delete
    Is there a switched 12v from the dome light connector that can be tapped into?
  14. Aug 12, 2024 at 7:37 PM
    Vtallysx4
    Vtallysx4 Well-Known Member
    V
    2023 Tacoma TRD Sport
  15. Aug 13, 2024 at 12:52 PM
    BSK
    Trabant 501 Kombi
    That's tapping into the mirror harness. Already have those pins mapped out. Was trying to see if there is anything for the dome light connector.
