Wiring input needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Sep 2, 2015.
  1. Sep 2, 2015 at 10:54 AM
    vijay
    vijay [OP] Well-Known Member
    I need to pull power for a LED light bar and a CB radio. The fuse panel under the hood has two slots that is free(it's not marked as well, see last picture). I plan on tapping into this. Do you guys think this is a good idea? The LED light bar needs a 30/40 A fuse(260 watts).
    See pictures...the red wire is my tap out. I will have to put a hole in the panel box ;)
    There should be a fuse panel inside the truck as well, correct? may be that is a better option?
  2. Sep 2, 2015 at 1:21 PM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
  3. Sep 2, 2015 at 2:27 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the LED bar and CB should pull directly from the battery (fused of course) and be on a relayed switch..... as every other circuit is on the truck.
  4. Sep 2, 2015 at 2:30 PM
    99Runner3.4
    99Runner3.4 Well-Known Member
    Lucas
    2009 4x4 TRD Off Road DCSB
    I have light bars that I wired directly under my radio. Didn't use the fuse box just bought fuses and a fuse connector
  5. Sep 2, 2015 at 2:56 PM
    vijay
    I'm sorry, but how did you pull power from radio? any pictures?
  6. Sep 2, 2015 at 3:03 PM
    vijay
  7. Sep 2, 2015 at 3:18 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    I agree!
  8. Sep 2, 2015 at 3:54 PM
    99Runner3.4
    Lucas
    The switch is mounted under the radio. I didn't pull power from it. Sorry that was unclear. I mounted the light bars and wired it according to this diagram. Then I ran the wire through the dash under the wheel and under the radio.
  9. Sep 2, 2015 at 4:24 PM
    vijay
  10. Sep 2, 2015 at 4:26 PM
    99Runner3.4
    Lucas
    Haha yea that 14$ beats the 40$ I spent on separate wires and fuses lol. Your posting this already smarter than me xD
  11. Sep 2, 2015 at 8:16 PM
    vijay
    That, I did not know. There is option to put fuse in there and I was under the impression that I can put any Amp fuse. Ho well, that idea is out now anyway. I will tap out from the battery and then get an inline switch before using the wiring that I bought on Fleebay.
