Wiring piggybacked, ecu nonexistent?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RJSR5, Sep 6, 2008.
  1. Sep 6, 2008 at 7:39 AM
    RJSR5
    RJSR5 [OP] New Member
    AB,Canada
    00 Tacoma SR5
    2000 Tacoma 4x4. Was looking around up under dash and found this. Where is the ecu? The Toyata clip/harness was tucked up behind, whats with all the pink wires and piggybacks? How is this truck running with no factory ecu seen? The large flat wire clip/harness, is a aftermarket what? All I wanted to do was try out the grey wire mod, now i'm scratching my head.
  2. Sep 6, 2008 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    IIRC, the ECU is on the passenger side. In the kick pannel, I belive. :)
  3. Sep 6, 2008 at 8:18 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    All ECU's for truck are behind the Glove box about the AC housing.
    Just have a screw driver and a 10MM socket to get it out.
    Also discontect your battery before you start messing with the ECU...
  4. Sep 6, 2008 at 8:47 AM
    RJSR5
    AB,Canada
    00 Tacoma SR5
    So in my second pic the 10pin clip with the same colour code wires as described in the "grey wire mod" is just there for??
