Wiring Question for Activator III
Discussion in 'Towing' started by Ultima GTR Guy, Aug 24, 2008.
  1. Aug 24, 2008 at 6:40 PM
    Ultima GTR Guy
    Ultima GTR Guy [OP] Active Member
    Carlsbad, CA
    09 Double Cab Short Bed TRD Sport
    I have an 09 Double Cab with Tow Package and bought an Activator III brake controller. I also bought a Tekonsha Toyota Brake Control Harness (model 3040-P). The harness has 2 connectors: one that fits the connector under the dash and one that fits the Activator III. In the harness it also has a white wire with a spade on it that doesn't seem to go anywhere. Could this be another ground? I used an Ohm meter and found it has continuity to ground. What should I do with this and where should I connect it?
    Thanks,
    Paul
  2. Aug 24, 2008 at 7:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....im guessing thats an extra ground, so you could cut the spade off,put an eyelet on it, and connect it to the closest point you can find that is grounded,and out of the way.
  3. Aug 25, 2008 at 5:00 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Sorry for my late response on this.
    You and Tacomaman are both correct. It is a secondary ground wire. The reason for it is because the majority of all trailer wiring problems stem from a bad ground, so the more places that the cround wire connects, then the less chance for that problem. There is a ground bold behind the driver's side kick pannel that you can connect it to.
