wiring subs
Discussion in 'Audio & Video' started by steveomalilay, Nov 17, 2011.
  1. Nov 17, 2011 at 12:14 AM
    steveomalilay
    steveomalilay [OP] Well-Known Member
    steven
    sebastopol california
    97 4runner 4x4
    k&n air filter
    can you guy tell me / show pictures how to wire my sub and amp in mt 2005 reg cab :confused:
  2. Nov 17, 2011 at 5:36 AM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    You are going to need to do A LOT of research on your own, as no one is going to want to walk you through the whole progress. The basics (with pictures) are in a "sticky" at the top of the A/V forum.
    The really basics. You will need to buy a wiring kit of the correct gauge depending on the power of your amp, something to carry signal from your H/U to the amp, and speaker wire.
    If that is confusing, you are probably better off paying someone to install it for you. Not to be rude, but this isn't rocket science, it just takes research and attention to detail. If you are unwilling to do the research it may be an incredibly frustrating process for you.
  3. Nov 17, 2011 at 7:07 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Ill go a little further.
    Amp wiring kit - Power wire, with fuse, to the (+) on the amp
    Ground wire to chassis of truck to the (-) terminal
    Speaker wire from amp output to sub terminal on the sub box.
    If using stock deck:
    Line out converter, wired to the speaker outputs, with an RCA cable going to the amp.
    Remote wire should be part of this, or you will have to tap a fuse that is live with ignition
    Or an amp with speaker level inputs
    If using aftermarket deck:
    RCA from the back of the unit to the amp.
    Remote wire using the harness on the deck.
    If any of this is confusing, see the above post, last paragraph.
