Wiring through firewall
Discussion in 'Technical Chat' started by Gunshot-6A, Apr 12, 2017.
  1. Apr 12, 2017 at 12:54 PM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I have 4 external relayed accessories I have plans to connect to carling switches in the dash. Instead of making 4 separate wires run through the firewall, is there any risk or downside to using an 18-4 wire so I only have to run a single (bigger) wire through once to make for a cleaner look?
    I figure if i disconnect an accessory, i could just cap off one of the unused leads.
    example:
    https://www.lowes.com/pd/Southwire-18-AWG-4-Conductor-Jacketed-Sprinkler-Wire-By-the-Foot/50142294
    What am I missing?
  2. Apr 12, 2017 at 12:55 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    That is one way to do it. Don't see anything wrong with that.
  3. Apr 15, 2017 at 8:13 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Edit: failed at reading. Sensor wire is fine for feeding relays.
  4. May 10, 2017 at 6:25 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Perfect. Nice writeup.
    I'm using a multi conductor cable to my switch and to my roof too. (through an access hole I drilled under my factory rack)
    They are more convenient to route rather than multiple single conductors and the plastic conduit.
    I have a manual and there is a convenient plug through the firewall on the passenger side.
