Wiring up lights on roof
Discussion in '1st Gen. Tacomas (1995-2004)' started by cr500taco, Sep 22, 2012.
  1. Sep 22, 2012 at 1:56 PM
    cr500taco
    cr500taco [OP] Well-Known Member
    D
    Northridge
    4WD
    K&N intake.
    I have a Yakima basket on the roof of my '97 extra cab and have a couple of pairs of lights that I want to put on it, front and rear.
    What's your suggestions on how to run the wires from the cab to the lights?
  2. Sep 22, 2012 at 3:12 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    If you made holes to mount the rack I'd make one more...but that might be a hassle seeing you would have to remove the headliner right? :(
  3. Sep 23, 2012 at 11:46 AM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    Didn't make any holes to mount the rack. It is clipped on the door frames. And yeah, trying to avoid removing the headliner and drilling a hole in the roof if there's other options.
  4. Sep 23, 2012 at 11:52 AM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Run the wires through the rear window seal.
    Just take a flathead and pull the seal back a little bit. Once you shove the wires in you can push the seal back in.
    I did this with the wire for my XM antenna. Never leaked.
  5. Sep 23, 2012 at 12:03 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    I ran my wires up the seal of my driver side door. There's a gap/hole that you can run wiring under the hood, through the fender, and right up to the seal behind the door. Worked perfect for me.
  6. Sep 24, 2012 at 9:37 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    I might just do it that way, thanks.
  7. Sep 24, 2012 at 9:43 PM
    kadeevans
    kadeevans Member
    kade
    east texas
    tacoma 4x4
    285 75 16 tires
    what basket and mounts did you use
  8. Sep 24, 2012 at 9:47 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    It's a Yakima Loadwarrior on top of a Yakima rack. Don't have the basket on the rack right now, as I only put it on when I need it.
