Wisconsin Tacomas and bad financial advice
Discussion in 'Mid West' started by Thatbassguy, Dec 19, 2008.
  1. Oct 15, 2024 at 11:42 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    The previous post does not imply we're done riding for the year....
    Adventure time on Saturday.
    We'll go explore more into Clark Cty Forest. N./N.E. of Fairchild.
  2. Oct 15, 2024 at 12:29 PM
    Pixeltim
    Pixeltim Misunderstood member
    77 square miles surrounded by reality.
    '15 Black DCLB SR5
    Tires, Softopper, fully armored, winch, many pinstripes.
    That looks like an interesting area
  3. Oct 15, 2024 at 2:34 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Rewired the Viair w/ 3' 8ga. :D chord and a 50amp Anderson plug.
    (Had to drill a bigger hole).
  4. Oct 15, 2024 at 2:52 PM
    Aztec120
    Aztec120 The Road To Hell Is Paved With Stock Tires
    Cisco
    Milwaukee
    La Tortuga '17 SR5 DCSB
    Leer Topper 90% Chrome Delete
    I'm trying to remember the consensus when batteries were last brought up. Mine is finally starting to give out on me. Rockauto has some solid AGM options. Thinking of getting this one.
    The I remembered something about the alternator not playing nice with AGM's or something like that
  5. Oct 15, 2024 at 3:26 PM
    rubbersidedown
    rubbersidedown Well known voider of warranties
    Dean
    WI
    2020 Tacoma TRD OR Long Boi Voodoo Blue
    Some info here on the AGM batteries and alternator output: https://www.tacomaworld.com/threads/agm-battery-upgrade.805083/
    Basically, the stock alternator doesn't put out the max voltage that the battery can take. You can get a tune to fix that, give it an occasional trickle charge for a while, or do nothing. I think all 3 options have the same results. Personally, I kinda do option 2 with my X2Power AGM. I bought a Noco Genius2 and I like to plug it in for a few hours before going on a longer trip or off roading. I haven't measured voltage, but do it just for peace of mind I guess.
    Others on here are far more knowledgeable than I in these matters, but so far this has worked out fine for me.
  6. Oct 15, 2024 at 3:44 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    AGM is expensive. I just run a 27F in both trucks and I've yet to kill one, lights and all (even submerging ...)
    I do have both alternators tuned for higher output
    wi_taco, Aztec120 and rubbersidedown like this.
  7. Oct 15, 2024 at 3:52 PM
    Shellshock
    Iowa
    You don’t need to mess with the alternator output. You’ll get slightly less capacity. I spend the money on a solar panel vs raising the alternator output .2v
    put it on a trickle charger once in a while if you are worried about it
    I’ve had one in my tundra since 2019 and I don’t worry about it. Had zero problems.
  8. Oct 15, 2024 at 4:34 PM
    Aztec120
    Cisco
    Milwaukee
    Well.....long story short, I bought myself three-ish more years to ponder it :anonymous:
    Long story long......it was going to be a logistical nightmare trying to share one vehicle to get me, my wife, and my daughter all to work and school tomorrow.
    Especially considering we've changed our schedules to work around my mother-in-law being in Mexico all month.
    If the battery had died tomorrow I could have played the shopping game a little more. The kiddo is off Thursday to Monday from school so I took off work those days too.
    It's a shame really. It would have been a glorious snowball of spending to justify the Cascadia panel I want to get on the hood eventually.
  9. Oct 15, 2024 at 5:26 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    We're talking about stock alternators?
    and in what fashion do you have them tuned?
    (Trying to understand how to get more than 130amps out of a 130amp alternator)
  10. Oct 15, 2024 at 5:35 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Got my son's old car sold today. Long story short on the starter issue: it appears to be the same thing that caused the trans issues he was having a month or so prior...a bad body ground. Pulled the main ground off near the battery, sanded the paint off, coated with dielectric grease and Voila! All working like a champ!
    Anyhoo, the guy that bought the car showed up rocking this:
    Clean, ran like a top. The only flaw I found was on the cap, rear upper corner of the right side window had developed a crack. Well, he did have Ranger hubcaps on it...:eek:.
    taoist, Tacos4ever15, wi_taco and 8 others like this.
  11. Oct 15, 2024 at 6:10 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    am-autoparts is having a headlite sale! up 55% off!!!!!!
    wi_taco likes this.
  12. Oct 15, 2024 at 6:10 PM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    14v output vs 12v
    Tuned or rather, adjusted through the now defunct TechStream platform.
    Cracked versions of TechStream Lite still work, many tuners still use it for a multitude of adjustments and customizations with Toyotas (minus the Supra, you need BMW's iSTA software for that. Junk)
    wi_taco and bkhlrTaco's[QUOTED] like this.
  13. Oct 15, 2024 at 9:06 PM
    Shellshock
    Iowa
    You can’t adjust the output with techstream. It’s part of the tune file created with vF tuner in the alternator tables.
  14. Oct 15, 2024 at 9:08 PM
    Shellshock
    Iowa
    It’s volts you are adjusting not amps.
    one of the sparkys can jump in but the two are related in some way, more volts less amps or something. I’m just the guy that pushes buttons.
  15. Oct 15, 2024 at 9:11 PM
    Shellshock
    Iowa
    @Pixeltim
    are you still interested in bed mat and or molle panel I have? May be meeting up with @rubbersidedown for the softopper so could tw express if still interested
  16. Oct 15, 2024 at 10:04 PM
    Pixeltim
    '15 Black DCLB SR5
    What was the deal on those? I kinda forgot…
    wait, yes on the bed mat, where does the molle install?
    I’m probably yes on that too, just want to know what I’m getting into..
  17. Oct 16, 2024 at 3:17 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    wi_taco and bkhlrTaco's like this.
  18. Oct 16, 2024 at 3:20 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
  19. Oct 16, 2024 at 4:17 AM
    Shellshock
    Iowa
    sparkystaco and CygnusX191 like this.
  20. Oct 16, 2024 at 4:20 AM
    Shellshock
    Iowa
