Wisdom on changing and braking in new rotors and pads/
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Feb 25, 2012.
  1. Feb 25, 2012 at 12:03 AM
    x2468
    x2468 [OP] Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    So my powerslot rotors and hawk lts pads came in the mail. I plan on installing them in the next few days. Is there any wisdom the forum would like to bestow upon me, as far as swapping out the oem parts for the new parts, and braking them in? Any advice would be appreciated.
    Thanks in advance.
  2. Feb 25, 2012 at 2:41 PM
    Stew
    Stew Well-Known Member
    Stew
    Greenville, NC
    White 04 Single Cab 2.7 4x4
    2.5in ^, debadged, fog light mod, deck plate, line-x, tool box
  3. Feb 25, 2012 at 4:43 PM
    ratso
    ratso Well-Known Member
    northern ca2
    sr5
    Camburg coilovers,ARB, warn 9000,avic d3,KN cold air,poweraid, optima yellow top,line x
    I would say don't slam the brakes on go easy for the first few miles.Once the pads and rotors go through some heat cycles there good to go.
  4. Feb 25, 2012 at 5:42 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Make sure you hit the rotors on with a mallet or they'll rub I just installed the same combo
  5. Feb 25, 2012 at 9:48 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    I think what he means is that you should clean off any corrosion on the hub surface with a wire brush of some sort and apply some antiseize so that the rotor will seat correctly and prevent corrosion in the future. :)
    If you clean it up you won't have to smack it on.
  6. Feb 27, 2012 at 9:45 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    follow the break in procedure suggested by the pad manufacturer.
  7. Feb 27, 2012 at 10:48 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Couple of hard stops and you are good to go
  8. Feb 27, 2012 at 12:27 PM
    bellassaiw10
    Currituck NC
    The only corrosion I had was just caked on brake dust which I cleaned off they rubbed on the rotors cause they weren't seated properly... Brakes and rotors work fine now just make sure to remove your brake fluid cap, then get in afterwards press the pedal until your calipers fill back up and drive around the block
  9. Feb 27, 2012 at 9:03 PM
    x2468
    Vermont
