Wishbone Runner's Build
Discussion in '4Runners' started by Wishbone Runner, Sep 12, 2012.
  1. Nov 11, 2014 at 12:54 PM
    #261
    Wishbone Runner
    Wishbone Runner [OP] Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Also, the CEL went away this morning, I would have thought the super cold we just got would make it more likely to leak but IDK.
  2. Nov 11, 2014 at 1:09 PM
    #262
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Take this with a salt lick and the caveat that I know nothing about this particular code but. ....
    SOME codes on SOME vehicles will trip if conditions are met a single time and will only reset themselves if the conditions are negative for many consecutive times.
    This MAY be a good sign that the code was a false positive. How many times/how long have you run the thing since it first threw the code?
  3. Nov 11, 2014 at 1:50 PM
    #263
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Yes, and no. The manual doens't say to rotate the crankshaft off of TDC, as a general rule that means no interference. At new Model training they told us they were. Just be careful, if it binds, don't force it.
  4. Nov 11, 2014 at 3:04 PM
    #264
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    The first sign was swooshing in the dash (gas in the coolant) the last few weeks. Then, checked the coolant Friday, way low, topped it off. Drove up to Edwards Friday night, no CEL, Saturday to Glenwood and back, no CEL, then Sunday morning cold start CEL on. Check everything, looked good, pulled the battery to clear it, drove to Glenwood, no issues, truck sat all day whioe fishing, start it up in the afternoon, CEL on. Went to Autozone and the confirmed it was P0306, which I knew it would be. Did not reset it, have shutoff and restarted maybe 6 times since then, and the code was gone this morning.
    Good to know, and thanks again for the advice. I will be studying the manual carefully before messing with the chain/timing.
    I assume yours had the same P030X (likely P0306) code?
  5. Nov 11, 2014 at 4:12 PM
    #265
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Well either I missed something or you should've mentioned that earlier :eek:
    Pressurized coolant and mixed fluids should tell you head gasket without a diagnostic code. Unless there's some, even worse cause I'm not aware of.
  6. Nov 11, 2014 at 7:08 PM
    #266
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Sorry, guess i missed mentioning that . . .
  7. Nov 11, 2014 at 8:06 PM
    #267
    thefatkid
    Brian
    Colorado
    2004 thingy
    I had the p0306. Every one of the head gasket jobs I did on the 4runners were p0306.
    The thing that sucks about the way these blow is it is all into the combustion chamber. The coolant doesn't mix with the oil, it would have to pass the rings to make it to the oil. The way I find it, pressure test the cooling system and bore scope the cylinder. On a hot engine you might even be able to see steam coming out of the spark plug hole. On my 4runner it also killed both the A/F sensor and Oxygen sensor. Coolant down the exhaust stream.
  8. Nov 12, 2014 at 6:21 AM
    #268
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I thought cylinder pressure made it into the cooling system over pressurizing it? Or is coolant seeping into the combustion chamber when the motor is off and the coolant is still pressurized? (engines in general, not the 1GR specifically)
  9. Nov 12, 2014 at 6:32 AM
    #269
    thefatkid
    Brian
    Colorado
    2004 thingy
    Not really, because the radiator cap has a relief around 14-15psi the system will not over pressure. The issue comes from the combustion gasses replacing the coolant (air pockets).
  10. Nov 12, 2014 at 6:49 AM
    #270
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Yeah, that's what I mean. I figured you lose your coolant out the relief rather than into the combustion chamber.
    I guess I could quit cluttering up James' build thread though. :D
  11. Nov 12, 2014 at 9:48 AM
    #271
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    That's what I figured. Glad that others have gone through this before me so I am not wasting big bucks on chasing gremlins and can cut right to the problem.
    Not cluttering at all, Brian knows his shit and this is all new to me, so the more info the better, and hopefully help someone else down the line :thumbsup:
  12. Nov 12, 2014 at 11:06 AM
    #272
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Let us know when we can come over, drink your beer, lean against your truck, get in the way, provide useless information, act like we're helping, and put the timing chain on wrong so we can see for sure if you can mate a valve and a piston.
  13. Nov 12, 2014 at 11:39 AM
    #273
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Ah!.. Brett gets where I'm coming from :thumbsup:
  14. Nov 12, 2014 at 1:23 PM
    #274
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I knew I could count on you guys for something! Parts will be ordered next week, then I will probably start the tear down the following weekend, probably no progress Thanksgiving weekend, completion hopefully the following weekend, 12/6. So I would say 12/6 some beer can be drank.
  15. Nov 12, 2014 at 2:48 PM
    #275
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  16. Nov 12, 2014 at 3:04 PM
    #276
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Are they "torque to yield"?
    If so, get new ones no questions asked.
    Looked at RockAuto yet?
  17. Nov 12, 2014 at 4:55 PM
    #277
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Not sure, thefatkid didn't seem to think so, said they had stretch a spec to reuse or not, and reused his. OEM ones are $7x8, $56. Need to look into the yielding a bit further, maybe have them on hand and return as needed, again not that expensive in the grand scheme of things, probably better to just do it and not worry about it.
    #90910-02162
    http://www.ebay.com/itm/TOYOTA-OEM-...Parts_Accessories&hash=item3f3522bbdb&vxp=mtr
    RockAuto was more expensive or didn't have the stuff I have already ordered.
  18. Nov 12, 2014 at 6:40 PM
    #278
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Looks like head bolts are $35 - $52 at Rock Auto. Full gasket set is $128. Water pump is $58 - $98 :notsure:
    I've had real good luck with them in the past. I bought the reman heads for my ranger from a specialty head remanufacturer but the bolts and gaskets all came from RockAuto.
  19. Nov 12, 2014 at 6:46 PM
    #279
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I have no problem with RA, order from them all the time, but going full OEM on this job, which they don't carry.
  20. Nov 12, 2014 at 6:54 PM
    #280
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    So it sounds like this a disturbingly common problem?
    Is it somehow unique to the runners or does it happen frequently in the tacomas too?
    How many miles are on yours?
