Wishbone Runner's Build
Discussion in '4Runners' started by Wishbone Runner, Sep 12, 2012.
  1. Jun 2, 2015 at 7:48 PM
    #441
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Oh you know you liked changing the third in the dirt.
  2. Jun 3, 2015 at 1:17 PM
    #442
    Wishbone Runner
    Wishbone Runner [OP] Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Actually not that bad of a thing to do in the dirt, much easier than I anticipated.
  3. Jun 3, 2015 at 1:36 PM
    #443
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Talk about good timing
  4. Jun 3, 2015 at 2:26 PM
    #444
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    yeah, u had it easy gettin it out. was kinda jealous it was that easy compared to when i did mine
  5. Jun 3, 2015 at 5:28 PM
    #445
    Night Eagle
    Leo
    2014 TDR Off Road
    Ya I was kinda surprised how easy it went back together.
  6. Jun 3, 2015 at 7:39 PM
    #446
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Hell yeah! Was thinking of running it off the CO2 tank, but that wasn't going to be cheap either for a manifold and regulator.
    Beginners luck?
    Don't rub it in Ryan's face :D
    Got lots of pics of you guys to go through still.
  7. Jun 3, 2015 at 7:43 PM
    #447
    wrmathis
    Bonaire, GA
    parts and stuff
    well hurry up :p
  8. Jun 3, 2015 at 8:13 PM
    #448
    Night Eagle
    Leo
    2014 TDR Off Road
    I have very few pics. Just been kinda lazy about putting them up.
  9. Jun 4, 2015 at 5:47 AM
    #449
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    James, how did you strap that tank to your rear bumper exactly? Is it a 20lb??
  10. Jun 4, 2015 at 8:01 AM
    #450
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    20#er, built the mount then strapped to it via a big ass ratchet strap. Worked flawlessly. Here is the mount, it bolts to the swing out.
    395BF009-194A-4260-92F5-18AA678A08E0_zps_a04db379332302e68e3800e4adb0ea199e469285.jpg
    RockyMtnTRD[QUOTED] likes this.
  11. Jun 4, 2015 at 8:06 AM
    #451
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Here is the aftermath of the diff explosion, and where it happened, on Behind the Rocks.
    CAADFB8B-E527-4534-8186-2FD8819C8E8D_zps_980b930d4d8f0f5b115c15d4c6b31a3afda1104b.jpg
    e-_3TH_UhPXYhx0N_0c2TvLSNhqGy7YGNmpbSAxo_44b3fe3899e4753479b994d91eb25717e983cf77.jpg
  12. Jun 4, 2015 at 3:52 PM
    #452
    RockyMtnTRD
    Noah
    Colorado
    '11 TRD OR
    hack job
    Dang thats badass!!!
  13. Jun 10, 2015 at 10:11 AM
    #453
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    A few more pics of the bumper swingout Moab
  14. Jun 17, 2015 at 8:25 PM
    #454
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Does this thing have a functioning locker yet?
  15. Jun 18, 2015 at 9:25 AM
    #455
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    It does, but I am not 100% sure it is leak free though. From the pump all the way to the 3rd is leak free, and not rotating the system is leak free, but right after I hooked the line up it would leak when spinning the tires, through the diff breather which usually means the main O-rings are fucked, then driving it would kick on once every 30 seconds or so. Since then I talked with ECGS quite a bit and they suggested the main O-rings as well, but I then changed the oil and re-seated the bulkhead fitting which has an O-ring that could cause a leak into the 3rd, and I have been leak free driving around on the street. I need to get up on some dirt and run it for longer than a block in a straight line to be sure though. ECGS has been great though, and if there are any issues that were their fault from setup they will make it right, and Brian is going to give me his old 3rd, and I can use it as a spare if I need to send this one back for any reason, or blow it up again :anonymous:
  16. Jun 18, 2015 at 9:33 AM
    #456
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Here is where I ended up putting the compressor and the new switch layout, I moved the lighting ones down by the shifter, the toggle is the VSC off, and will be replaced by a front locker one day.
    DBF6CA0E-FA2F-4642-8738-E7057F487EC1_zps_de6be8cc19643dcd4f9dea974bc3ca0cc3526848.jpg
    4A66838E-7DB9-4A88-B4B4-67C06621593F_zps_2cf356b2ff0180b0f5c8d2f862a29218fea37909.jpg
  17. Jun 18, 2015 at 9:37 AM
    #457
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Also finally took my Moab raffle prize out of the box and was pleasantly surprised, Front Runner spare tire grill. Quality made product, stainless top and beefy legs, I have been driving around with it all week and hasn't moved a bit, we will see how it stays offroad, look forward to using it this summer. I was amazed to see this thing retails for $160! :eek:
    D880DA2C-E9F1-4CD2-904F-F7A015C308B0_zps_70fda65c79ab9b6bb56a7982f8af0710e75a699e.jpg
    3CBE9626-71DD-406F-84CE-82ECAC90E970_zps_49f0c8ca071eb81a4cc72ef5d34a3b48f32800af.jpg
  18. Jun 18, 2015 at 9:43 AM
    #458
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Love your build. I seen people with the grill use short ratchet straps to make sure the grill doesnt fall off a swingout.
  19. Jun 18, 2015 at 9:56 AM
    #459
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks! I will probably strap it when hitting the dirt for extra security, but it seems pretty damn solid as is.
  20. Jun 18, 2015 at 5:53 PM
    #460
    Squeaky Penguin
    Brett
    Alright, I'm bringing some steaks next trip to test that thing out and paying you and Eric back for food.
