Wishbone Runner's Build
Discussion in '4Runners' started by Wishbone Runner, Sep 12, 2012.
  1. Nov 2, 2018 at 6:42 PM
    #1101
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    How many ugga dugga's is that?
  2. Nov 2, 2018 at 9:58 PM
    #1102
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    At least 4 with a couple brapp brapps thrown in for good measure
  3. Nov 8, 2018 at 7:23 AM
    #1103
    Wishbone Runner
    Wishbone Runner [OP] Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Knocked it our yesterday, pretty easy job. I acidentally ugga dugga’d the nut off and forgot to count turns, but reused the same one and was quite easy to get it back to where it was with the groove in the pinion. So far so good.
  4. Nov 21, 2018 at 11:59 AM
    #1104
    Darklight
    Darklight Well-Known Member
    Bobby
    Charlotte,NC
    2008 Black SR5 V6 4Runner
    http://www.toyota120.com/forum/showthread.php?t=26920
    Congrats James! Hope you guys are doing good!
    Bobby
  5. Nov 21, 2018 at 12:05 PM
    #1105
    Darklight
    Bobby
    Charlotte,NC
    Bummer on the rear seals and parking cable. Sounds like the seals were easy to tackle though.
  6. Feb 4, 2019 at 5:25 PM
    #1106
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Undertook sonr tracker case maintenance, had an oil leak from the actuator which after some research was caused by a small oring between the actuator and case, and possibly 2 seals on the shift rods. Of course this requires pulling the entire case, breaking it open, pulling a ton of crap apart etc, all for $8 worth of seals and oring. Followed this write which was close, but was for the 8 banger and the V6 case has another rod for 2=>4x. EF159D6E-F7A8-4F35-B060-77C38EBE6070.jpg
    Went fairly well other than finding a broken tooth in the case that seems to have come from one of the pleantary gears/rings, not sure what it’s function is, everything was working well prior to disassembly. @thefatkid any ideas of how bad this is?
    In the first one below you can see the tooth missing, and in the second one of the teeth in place, the should be three total.
    Night Eagle likes this.
  7. Feb 4, 2019 at 8:19 PM
    #1107
    thefatkid
    Brian
    Colorado
    2004 thingy
    It is keying for the syncro for smooth open to locked center differential operation. I've never seen one broken so I can't comment on how it will affect operation.
    Wishbone Runner[OP] and dtaco06 like this.
  8. Feb 4, 2019 at 9:09 PM
    #1108
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Hmm, can that key be replaced by itself? Never had issues so far . . . Maybe a new baller Tcase is in my future. Anyone know what happened to Inchworm? Seemed to have disappeared off the face of the earth. Marlin doesn’t seem to make the lefty anymore and Atlas are stupid expensive.
  9. Feb 4, 2019 at 9:33 PM
    #1109
    thefatkid
    Brian
    Colorado
    2004 thingy
    Anything can be replaced, I'm not sure that would require any press work. I'll look more the next time I have one out.
    Inchworm was a part of Lowrange Off road. Think partners of sorts. Lowrange sold to TrailGear but heard nothing of Inchworm. It is like they disappeared.
  10. Feb 4, 2019 at 9:37 PM
    #1110
    thefatkid
    Brian
    Colorado
    2004 thingy
    Couldn't drive because the rear diff or something locked up in the transfer case?
  11. Feb 4, 2019 at 11:40 PM
    #1111
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    So in the FJ case when twin sticking you have those three keys that can fall out. They aren’t broken but can fall out if not aware of. A dab of grease will old them in while assembling everything. Rocksolidtoys has a write up on their site back in the day but the forum is gone. Not sure if it’s on here tho in their sub forum
    Maybe @awsumdc can chime in
    teamhypoxia likes this.
  12. Feb 5, 2019 at 6:51 AM
    #1112
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Can you drive with nothing supporting the rear axles in the center. They don't contact the housing? Obviously just to get off the trail.
  13. Feb 5, 2019 at 7:41 AM
    #1113
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    So are you saying they are easily accessible/replaceable? It looked like there was a clip on the end of the shaft that they were on, is everything else pressed on from there or do they just slide right off.
    Regardless it is going back on the truck today, if it is fucked I may go FJ for the time being, can’t fork out for anything nicer right now.
    dtaco06 likes this.
  14. Feb 5, 2019 at 9:34 AM
    #1114
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Been looking at them all morning, found a bunch of newer 4R cases for ~$250 with free shipping, without twin sticking them only other mod is the ADD switch/harness for $30. Will probably go this route if mine explodes then fix it up at some point. Sigh.
  15. Feb 5, 2019 at 1:03 PM
    #1115
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yeah, but that doesn’t fix any Tcase issues, wish I could find a Lefty.
    It’s back together and works, sort of. It seems I’ve lost AWD, turning the knob to 4 results in blinking, but the truck is in 4wd, binding on sharp turns. Then hitting the diff lock button stops blinking and VSC off appears, no change in functionality. 4lo works as well, but will not go into it while blinking. Should have left the damn thing alone, going to start collecting parts for a manual case down the road.
    w.adventures likes this.
  16. Feb 5, 2019 at 1:17 PM
    #1116
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Called Low Range, Inchworm is no more. So the only single case options are the Atlas or an FJ/4R manual which can have a taco box added. I feel like the Atlas is a better/simpler option, but $$$$.
  17. Feb 5, 2019 at 1:43 PM
    #1117
    thefatkid
    Brian
    Colorado
    2004 thingy
    You might reach out to inchworm on the facetubes. Not sure how the split went down with LowRange selling to Trail Gear
  18. Feb 5, 2019 at 1:48 PM
    #1118
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    They legit are out of business, any contact info for them is LowRange
  19. Feb 5, 2019 at 6:28 PM
    #1119
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yeah, that link I posted covers most of it, I would need to open it back up, or the actuator, neither of which I’m up for so long as I have 4 h/l I’m done fuckin with it til I get something better.
    Taco box needs both shafts altered as it pushes the Tcase back, so rear shorter, front longer.
  20. Feb 5, 2019 at 6:29 PM
    #1120
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Really wish someone made a clocking adapter for the stock case, Bud used to, but no more.
    dtaco06 likes this.
