Wobble/Vibration after 3" lift 2WD.
Discussion in '3rd Gen. Tacomas (2016+)' started by Chablo, Oct 9, 2019.
  1. Oct 9, 2019 at 4:48 PM
    Chablo
    Chablo [OP] Well-Known Member
    North Central, FL
    2017 Tacoma TRD Sport RWD V6 DCSB
    I've searched and haven't found much on the 2WD's. Installed the 3" lift and some 17x9's -12mm with some 285's. Had an alignment done immediately after. But it feels as if there is a bubble or flat spot in a tire. At 50-60mph I'm getting a wobble/vibration. Someone in a FB group suggested I get the tires re-balanced. Saying that it sounds mostly a tire balance issue and not so much needing a shim. Figured I'd ask here. What do you guys think?
    I'm going to be taking the truck to an actual Toyota dealership and let them balance them.
  2. Oct 9, 2019 at 4:52 PM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Usually if youre vibrating at a specific, reproducible speed, its gonna be a balance issue. The 50mph range has been my crap spot for balance issues on 3 different sets of tires as well
  3. Oct 9, 2019 at 4:58 PM
    Chablo
    North Central, FL
    Have you figured out a solution or even a slight remedy?
  4. Oct 9, 2019 at 4:58 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I would def not go through the trouble of letting the dealer balance your tires, for numerous reasons.
    Does the steering wheel have a corresponding shimmy?
    Move the front tires to the rear and see if it changes.
  5. Oct 9, 2019 at 4:58 PM
    JaCado
    JaCado Bad luck charm
    What brand tire did you install.
  6. Oct 9, 2019 at 4:59 PM
    Chablo
    North Central, FL
    The steering wheel shakes back and fourth slightly enough that i can see the shake in my arm and watch when holding the wheel.
    Toyo Open Country
  7. Oct 9, 2019 at 5:00 PM
    Rujack
    Most likely a balance issue then.
  8. Oct 9, 2019 at 5:01 PM
    Rujack
    And it’s a steady rhythm related to wheel / vehicle speed?
  9. Oct 9, 2019 at 5:02 PM
    Chablo
    North Central, FL
    Is there a reason why I should avoid the dealer for a balance? A tire shop is the original balancer of these wheels and tires.
    yes
  10. Oct 9, 2019 at 5:03 PM
    JaCado
    And they should make it right.... not the dealer. Road force balance the tires, could also just have a flat spot from being on the tire rack for a long period of time.
    hiPSI and whatstcp like this.
  11. Oct 9, 2019 at 5:04 PM
    Rujack
    Time, money, and “normal” or upsell on a new tranny :rofl:
    And you already paid the tire shop.
    It’s not that uncommon to need a rebalance.
    JaCado likes this.
  12. Oct 9, 2019 at 5:04 PM
    OMGitsme
    OMGitsme Well-Known Member
    2019 OR DCSB MGM
    You should avoid the dealer for anything other than warranty. Take it to a tire shop and get them rebalanced.
  13. Oct 9, 2019 at 5:04 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Why not take it back to the tire shop and get it road force balanced. They might do it free if you just bought the tires there.
    whatstcp likes this.
  14. Oct 9, 2019 at 5:14 PM
    Sterling_vH111
    Sterling_vH111 IG: @Sterling_vH111
    Sterling
    Fullerton, OC, SoCal
    2012 DCLB Prerunner V6
    Secretly Long Travel
    Anyone have any ideas about a cab vibration at about 70-75mph?
    the steering wheel is pretty calm, but the cab/ truck it self seems to shake.
    Ex: the passenger seat back visibly shakes pretty good.
    Tire rotations do not change anything, and alignment is good. Have also swapped cars with a friend, and from the outward view, the truck is perfectly stable. No tires/axle/parts that are obviously shaking the whole vehicle at speed.
    Only about 1.5” lift springs in the back, and a lift spindle & long travel up front.
  15. Oct 9, 2019 at 5:19 PM
    JaCado
    Body mounts/ cab mounts front and rear ok?... check those bushings and make sure they are torqued properly.
  16. Oct 9, 2019 at 5:31 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  17. Oct 9, 2019 at 6:38 PM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    I actually sought out a place that does road force balancing. If youve got Discount Tire in your area they did mine for $15 a corner. Still have a small shake but its nowhere near as bad
  18. Oct 9, 2019 at 8:20 PM
    Sterling_vH111
    Sterling
    Yes, body mounts are good. Front core support mounts are tight, but the bushings are shot for sure.
    JaCado likes this.
