wont go,Popping noise, fuel pump?
Discussion in '4 Cylinder' started by jmg5wakeboarding, Jun 27, 2011.
  1. Jun 27, 2011 at 6:42 PM
    jmg5wakeboarding
    jmg5wakeboarding [OP] Member
    Louisiana
    01 Prerunner
    3 inch body lift
    Ok my 2001 2.7 has been having a rough idle for a while. I changed plugs, fuel filter and MAF. still there. Now it starts sputtering so bad it will die sometimes. when it starts doin it i try to give it gas and it wont go and i hear this popping noise under the hood when i press the gas pedal. I think its the fuel pump just because it wont go, but wanna be sure befor i go through the trouble. Any advice?
  2. Jun 27, 2011 at 6:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    Popping noise? That's different. It could be the pump. It could also be the injectors or wires/coils or headgasket or..............I think you get the picture here.
    How does the oil look?
    Can you test compression?
    Is it throwing a code (CEL light on)?
  3. Jun 27, 2011 at 7:42 PM
    jmg5wakeboarding
    Louisiana
    01 Prerunner
    3 inch body lift
    Yes it does have the check engine light on but the last time it was read it was for an 02 sensor and fuel to rich. i guess i should start with the coils then.
  4. Jun 28, 2011 at 4:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    You should also replace that sensor. It sonuds like the AFR, which helps govern the fuel/air ratio.
  5. Jun 28, 2011 at 5:20 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Popping noise is fuel burning in the intake.
    Before you start your parts replacing marathon. Check the fuel pressure to rule out the pump. Check your spark plugs to make sure they are good. Look at the plug wires to see if there are any grey "arc marks", if so, replace. Distributor? look for pitting on the rotor, if so, replace. Coil packs have "arc marks", if so, replace. Clean your MAF sensor.
    Hopefully it has spit out a code. If you don't find a problem with the rest of the ignition and still have the problem, a cylinder specific code will tell you what fuel injector to suspect. Swap two adjacent injectors to see if the problem moves.
    If you find no other problems, check your compression. You might have a burnt valve.
    If you just start replacing parts, you will just waste money. You will also be no closer to being a troubleshooter.
  6. Jun 28, 2011 at 8:01 PM
    jmg5wakeboarding
    Louisiana
    01 Prerunner
    3 inch body lift
    ok thanks alot
