Wont shift out of 2nd when cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Jan 16, 2011.
  1. Jan 16, 2011 at 8:59 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    My transmission wont shift out of second when the engine/transmission hasnt warmed up. It wont shift until exactly 35mph (even if I take my foot of the gas). Once my engine/transmission has had time to warm up, the transmission starts to shift normally. This is the same with ECT Power and ECT Normal.
    Ive also noticed that when I press down on the accelerator, power is not diverted to the wheels immediately.
    My guess is low transmission fluid but I had the dealer check it out not to long ago when I took it in for its 90K maintenance.
    I dont want to take it to the dealer again just yet and was hoping someone could shed some light.
  2. Jan 16, 2011 at 9:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Mine is a little bit that way, but yours seems more severe. Mine doesn't shift correctly until the tranny fluid temp is about 90*F (ScanGauge II), it stays in 3rd. I don't think its a low fluid level that causes it.
  3. Jan 17, 2011 at 6:31 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Mine is slow to shift out of 3rd also, I just take it easy and on my daily route I can just about pin point when its cold out when its going to shift,It usually takes about a mile before it shifts.
  4. Jan 17, 2011 at 6:36 AM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Mine is the same, something electrical... It doesn't shift til it's warm or 2600 rpms.
  5. Jan 17, 2011 at 6:37 AM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    This is why I love my manual transmission. I shift when I want and don't rely on a computer.
    Rakan68 likes this.
  6. Jan 17, 2011 at 8:18 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    This is all 100% normal for our trucks and every other car. The computer tells the trans to hold the gears longer when cold in order for the trans and engine temps to rise more rapidly. Since lower temps mean more wear on parts, the engine wants to warm up as fast as possible.
    mohavestubbs likes this.
  7. Jan 17, 2011 at 9:00 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    This is the correct answer^^
    another good reason I give mine a 4 minute idle warmup. IMO it wastes more fuel cold-running in second than setting there idling for a few
  8. Jan 17, 2011 at 1:23 PM
    tacomacntry
    tacomacntry Joe's Auto Detail
    North East Florida
    Blacked out SR5 4x4
    K&N Cold air Cat back custom dual exhaust
    ^^agreed, same goes for my truck..when cold shifts to second but will stay in second until the truck has reached operating temperature and resumes normal driving. Programmed to do just that
  9. Jan 17, 2011 at 5:02 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Awesome, thanks for the replies!
  10. Jan 17, 2011 at 7:02 PM
    N.GA Taco x3
    N.GA Taco x3 Well-Known Member
    Kevin
    Georgia
    11 Pre DC Sport- 02 Pre DC OR- 12 DCSB 4x4
    My 2002 2wd V6 AT does the same thing, kind of annoying but i just take it easy till it shifts up, maybe 2 or 3 min and above 30 mph, something like that.
  11. Jan 17, 2011 at 7:09 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Nice to know your truck is just doin its thing-no?
  12. Jan 17, 2011 at 11:39 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Ha I thought it was just my truck :) nice. I like stumbling across cool info like this.
  13. Jan 18, 2011 at 12:09 AM
    BigJimHouse
    BigJimHouse Member
    Jim
    Kauai
    Mine does the same; heard that letting them warm up in neutral (E brake on of course) is a quicker way to warm up the trans than when in Park, maybe just a rumor.
  14. Jan 23, 2011 at 6:43 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Very GOOD question St Andrew !! I also Wondered the same thing, I have a 99 tacoma with the V 6 and the auto tranny and mine does the very same thing. Good to know Iam not alone.:)
  15. Jan 23, 2011 at 2:44 PM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    Mine does the exact same thing. How would the transmission fluid warm up if the truck is idling in neutral or park? I don't really think it would...
  16. Jan 24, 2011 at 9:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My scangauge shows that the tranny temps do actually go up while idling in park. Though the rate of increase is very slow. From a startup temp of 50*F it took over 4 minutes of idling to get the temp to 75*F.
    For grins, a cold startup, idling for 60 seconds, temp up yo 58*F, put it in gear and drive off. Within a half mile (~45 seconds) the temps is at 90*F and climbing quickly. Shifts normally at +90*F.
  17. Jan 26, 2011 at 2:20 PM
    athit87
    athit87 Member
    whoa I only thought it was my truck that does this. I've even started a thread on this til 707Bro lead me to this link. Thanx! Now, i feel much better..I was trying to find a fix for this for about 2 years now...so, one question...*sorry for the dumbness*..but do you guys think its safer to wait that 4 mins, or just go ahead and wait 1/2 of that?
  18. Jan 26, 2011 at 4:06 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I say you can ease out after a couple minutes if you hate the wait-BUT keep your speeds to like 25MPH till she wants to upshift.
  19. Oct 23, 2011 at 5:08 PM
    Super Heros Inc
    Super Heros Inc New Member
    Preston
    Dover, DE
    06 tacoma
    i'm actually having an issue with my manual transmission now, it shifts fine when I first start it up but after I let the clutch out the first time it doesn't want to shift into any gear. I have checked the fluids and all but have no idea whats going on
  20. Jul 3, 2012 at 12:03 PM
    ToyotaLoyal
    ToyotaLoyal New Member
    Illinois
    01 PreRunner SR5 Dbl Cab
    Thats really weird this is normal. It didnt do that when I bought it. 2001 PreRunner Dbl Cab purchased in 2003. Started not wanting to shift 2 years ago. I had to just baby it till I could afford to get it in the shop. Thought it was going to be more expencive than it was to flush it etc. Did that today for $179.00 including tax. They said all was good with it. It turned over 150,000 miles 2 days ago. Its an awesome truck....ABSOLUTELY LOVE IT! I will buy another one!
