wont start
Discussion in 'Technical Chat' started by buckbiter, Mar 11, 2011.
  1. Mar 11, 2011 at 9:46 PM
    buckbiter
    buckbiter [OP] New Member
    99 Tacoma
    I have a 1999 tacoma, 4x4 with a manual transmission. When i turn the key on it dosnt even light up the lights on the dash. I have replaced the battery, checked all the fuses and pulled out the ignition controler behind the key switch. I am wondering if there is something in the wiring that signals the key switch to work. something that it sends power to and has to have a return voltage to engage the other terminals on the ignition switch. Any ideas? Where might i get a wiring diagram?
    Thanks,
    NoGoJoe
  2. Mar 11, 2011 at 9:52 PM
    TmecTaco79
    TmecTaco79 Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
    Did you check for voltage to the key switch itself?
  3. Mar 11, 2011 at 9:55 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Or check the voltage on the battery? It could be the battery is deab, because the alternator could be bad and not charging the battery (since you said the battery was new).
  4. Mar 11, 2011 at 10:04 PM
    TmecTaco79
    Adam
    Escondido,CA
    If he swapped out the battery and the alternator was bad the truck would still start but wouldnt run for very long since all the juice would be coming from the battery. I don't think he's getting power either to the key switch or maybe through it.
  5. Mar 11, 2011 at 10:10 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Correct, but the alternator may have recently died or could of barely been working last and the battery could of had just enough voltage and over night (or sine the last time it was driven) could of died. Either way I would check battery voltage first.
  6. Mar 11, 2011 at 10:16 PM
    TmecTaco79
    Adam
    Escondido,CA
    If he replaced the battery with a new one and he still doesn't have any juice I don't know how he could have run it.
  7. Mar 11, 2011 at 10:19 PM
    S.B.
    Sean
    San Diego
    15 Taco
    idk if its was run or not after the new battery.
  8. Mar 11, 2011 at 10:25 PM
    TmecTaco79
    Adam
    Escondido,CA
    I don't think he has. But then again he hasn't thrown in anymore input so.... Who knows:notsure:
  9. Mar 11, 2011 at 10:42 PM
    DCtaco05
    DCtaco05 Well-Known Member
    dustin
    petaluma
    05 tacoma trd
    bone stock.. not for long
    make sure there is good connection to your battery terminals. there should be since u just replaced it
    and its gonna be the alternator. my buddies 2000 tacoma just had the same symptoms. i didnt think that even if the alternator was bad that it wouldn't start, i just thought it wouldn't stay running
    but we replaced the alternator and it started right up.
  10. Mar 11, 2011 at 10:46 PM
    TmecTaco79
    Adam
    Escondido,CA
    Weird. My friends car had a bad alternator but we were still able to start and drive it for 15 miles till we got it home. But then again that wasn't a toyota so it might have been wired differently.
  11. Mar 11, 2011 at 10:49 PM
    S.B.
    Sean
    San Diego
    15 Taco
    This is my understanding also. I could be a Toyota thing. I know that the 4-runners with the hard top wouldn't run with out the bolts in (for the top) with the top on.
  12. Mar 11, 2011 at 11:00 PM
    TmecTaco79
    Adam
    Escondido,CA
    WTF?? Really? I guess that's toyota being safe:D But those things look sick without the top on and made into a trail rig.
  13. Mar 11, 2011 at 11:01 PM
    DCtaco05
    dustin
    petaluma
    05 tacoma trd
    yea we had to move his truck to my house so i used jumper cables and started his truck with mine. it ran but when we parked at my house, he turned it off and then it wouldn't start. so it did run though. then like i said new alternator and what do you it know ? it starts
  14. Mar 11, 2011 at 11:01 PM
    TmecTaco79
    Adam
    Escondido,CA
    So is the op m.i.a. or what:confused:
  15. Mar 11, 2011 at 11:01 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Hells ya, I wish I could afford a trail rig.
  16. Mar 11, 2011 at 11:04 PM
    TmecTaco79
    Adam
    Escondido,CA
    Me too:( so much money tho. Especially if it's a dedicated trail rig.
  17. Mar 13, 2011 at 2:21 PM
    buckbiter
    99 Tacoma
    Thanks for the responses. Saddly I still have the problem.
    I have 12.4 volts on the battery and the same at the key switch. I have replaced the electrical portion of the key switch and still have no power to turn the engine over nor to the lights on the dash or any beepers. I am wondering if the key switch sends a voltage to something else and in return receives a voltage to operate the remaining contacts at the switch. I guess it could be a computer problem or something but i do have full voltage at the ignition switch. Thanks for your time.
    Still,
    NoGoJoe
  18. Mar 13, 2011 at 3:08 PM
    TmecTaco79
    Adam
    Escondido,CA
    I would say check the starter relay. Make sure you have power going to it and switch the key switch on and make sure you have power coming out.
  19. Mar 13, 2011 at 3:44 PM
    98tacoma27
    Ben
    Not Beech Creek
    It doesn't work that way. It's just a set of dry contacts. By your earlier description, it sounds more like a bad connection somewhere or bad terminals. Both the gauge and starter relay get their power via the switch.
  20. Mar 13, 2011 at 3:50 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Like he said ^, check your connections.
