Won't stay running.
Discussion in '4 Cylinder' started by duggravs, May 25, 2014.
  1. May 25, 2014 at 6:43 PM
    Flynbyu2
    Flynbyu2 Start every day with a smile and get it over with
    Ron
    Folsom, CA
    '10 Tacoma Sport
    When something like this happens to me, I put the old stuff back on, one item at a time, to see if it gets better.
    When I did my kid's 4Runner, he had two bad coil/plug boot combos. That's where I would look first.
    If it runs the exact same way as it does with the new parts on it, you buggered something up during the install.
  2. May 25, 2014 at 7:55 PM
    duggravs
    duggravs [OP] Active Member
    ricky
    torrance, ca
    stock 2004 prerunner
    airbox mod
    The only thing I changed were the spark plugs. And cleaned the throttlebody and the IAC. After I read on the forums. That it would fix the shaking. A free I cleaned and reinstalled. Tripled checked everything. And now it's having a hard time starting some times. It's really weird. I can't think of anything else I need to change or fix.
  3. May 25, 2014 at 7:57 PM
    duggravs
    ricky
    torrance, ca
    airbox mod
    I forgot to mention. I did add some seafoam to the gas tank and the crankcase two tanks ago before I change the plugs. I don't know if that would be the reason of it not wanting to start.
  4. May 26, 2014 at 7:07 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I'm sorry I meant to say fuel filter (not fuel pump). I've read some stories similar to yours that were solved by the fuel filter.
  5. May 26, 2014 at 7:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    With the truck idling tap the MAF lightly with the handle of a screwdriver, if the idle fluctuates the MAF is bad.
    Check engine electrical grounds are clean and tight (look for burned wiring that may be caught around the EGR)
    Make sure the EGR valve isn't stuck open or closed and is functioning properly.
    Check and replace brittle or dry rotted vacuum lines.
    Try a new Coolant Temp Sensor.
  6. May 27, 2014 at 10:03 PM
    duggravs
    ricky
    torrance, ca
    airbox mod
    It's weird. After cleaning the iac. In the beginning it started and ran great. But after I drove it and had it sit for a coue of hours. I didn't want to turn of stay on with out me pressing on the gas. It won't stay on I till it's warm. Then it's good.
  7. May 27, 2014 at 10:03 PM
    duggravs
    ricky
    torrance, ca
    airbox mod
    I tried tapping the maf and nothing happened. So it good. I just checked the egr valve. And it wasn't stuck and it held vacume. I cleaned it anyways. I checked all the hoses. And nothing seems brittle or ripped.
    After cleaning the egr. It turns on great and runs back to normal. I'm going to wait to see if it won't turn on again. But still no code or check engine light.
  8. May 28, 2014 at 8:04 AM
    Lpfan420
    Lpfan420 Well-Known Member
    06 base 4x2
    Could it be possible the computer just needs to reset? Not sure how far you are driving before needing to shut the vehicle off but it usually takes 50-100 miles to reset.
  9. May 28, 2014 at 8:09 AM
    duggravs
    ricky
    torrance, ca
    airbox mod
    I did reset the computer (disconnected the battery) after the second time I cleaned the throttle body and the iac. And latter that night after driving the truck for about 10 miles. It wouldn't stay running when trying to start it. Until It got to operating temp.
  10. May 31, 2014 at 11:10 AM
    duggravs
    ricky
    torrance, ca
    airbox mod
    ok. after cleaning the iac, tb and the egr.
    the egr seemed good. it opened and closed good. after cleaning the egr and driving for about a day. the check engine came on with a p0402 (egr excessive flow) and now im noticing my gas mileage getting worse. could it be the egr or something else? this is getting on my nerves!!!!!!!!!!
  11. Jun 3, 2014 at 9:27 AM
    duggravs
    ricky
    torrance, ca
    airbox mod
    I reset the computer. Drive it did about a day. And the check engine light came on again. So could it be the egr or could it be something else?
