Workbench Top Paint
Discussion in 'Garage / Workshop' started by Pster, Jun 26, 2009.
  1. Jun 26, 2009 at 7:46 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I found a great local steel processing center that is doing a few small jobs for me. One of them is cutting a 1/4" thick metal top for my 8' x 2' workbench. I am having them swirl the top, so I will need to seal it with something. Can anyone recommend something I should spray it with? Rustoleum makes more than a few clearcoat type finishs, but I don't know whether to use an Enamel, Polyurethan, Water Based, Oil Based, etc. I would something that will stand up to spilled gas and oil and household chemicals. Any ideas?
  2. Jun 26, 2009 at 11:05 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    have you considered just getting an aluminum topper?
  3. Jun 26, 2009 at 11:11 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
    The more I think about this, the more it seems that you should reconsider using mild steel for this. The paint isn't going to do a really good job for something like a workbench.
    If you're stuck with it, then I would just keep it sprayed down with some oil. Just a light coat to keep it from rusting.
  4. Jun 26, 2009 at 12:47 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    stainless steel, like restaurant kitchens
  5. Jun 26, 2009 at 12:57 PM
    cntstan
    cntstan Well-Known Member
    Chuck
    Wisconsin now, North Carolina will always be HOME
    08 DC SR5 4X4 ; 94 Ford Bronco
    3" Toytec coilovers, rear AAL,satoshi'd grill,ARE topper,TRD exhaust, All Pro winch bumper, Warn winch, All Pro skid, Pro comp 7089's, Supersprings, Wet Okole seat covers
    Will you be using this top for welding?
  6. Jun 26, 2009 at 1:31 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Possibly. I wanted something I could beat the shit out of and not dent. Most stainless tops can be dented. This 1/4" is NOT going to dent. It will be swirl polished and the guy that did it said I should just spray paint it with some clear coat....I just don't know what type of clear coat to use.
  7. Jun 27, 2009 at 5:53 PM
    jpg366
    jpg366 Well-Known Member
    TX
    09 Prerunner SR5
    I'd recommend blueing it... there is an old "cold rust" technique that produces a very tough finish. Degrease it, apply bluing, let it rust, steel wool it, and repeat. After a while, it stops rusting, and it's ready for a thin bit of light oil or paste wax.
  8. Jun 27, 2009 at 6:11 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Interesting idea....
  9. Jan 4, 2010 at 7:39 PM
    tisher49
    tisher49 Well-Known Member
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    K&N Air Filter, Westin Bull Bar with PIAA fog lights, Retrax cover, Alpine Head unit with I-Pod interface, maglite mount, Color matched grill surround w/ Grillcraft mesh
    you have a pic of how you covered your bench? Did you just lay the carpet on top or have you attached it some how?
  10. Jan 5, 2010 at 7:23 AM
    Yota1
    Yota1 Well-Known Member
    light oil, or wd40 from time to time. make sit very easy to clean, and to work on stuff. paint may chip if you are hammering ect.
    its a work bench, use it as one
  11. Jan 5, 2010 at 7:45 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    my bench in my shop sees quite a bit of extensive abuse... i am constantly welding, using the plasma cutter, grinding, and just beating the crap out of it in general. i choose to use 3/4" MDF as the base, then covered that with a thin sheet of diamond plate. thus far it has held up great, the diamond plate does show some abuse but nothing other than cosmetic damage...
  12. Jan 5, 2010 at 9:42 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    Yeah, I topped mine with some "sacrificial" plywood. I figure it's gonna get abused pretty badly (eventually), and resurfacing it even as often as once a year is cheap. I'm going to mount a vice with a strike plate on the front right corner if I really need to bang on something.
