Workload of Factory Tow Hooks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phum86, May 22, 2017.
  1. May 22, 2017 at 12:07 PM
    phum86
    phum86 [OP] Active Member
    Conway AR
    2014 Prerunner SR5
    Checked all over and could not find a answer so figured I would try here.
    Does anyone know the workload of the factory tow hooks that come on 2014 tacoma prerunners?
    Based on most things I have read to be used for recovery points, they need to be replaced with something more substantial, but figured I would ask.
    Thanks.
    ChadsPride likes this.
  2. May 22, 2017 at 12:19 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    They will probably work fine in a pinch. I would wait to upgrade them until they actually bend
  3. May 22, 2017 at 12:23 PM
    fingers1126
    fingers1126 Well-Known Member
    Fall River, Ma
    2010 Tacoma AC 4x4 4.0
    I wouldnt think they are worth much from factory, but for some light duty stuff i would try but anything strenous hell no..... I have seen others on chevrolets bend easy .....
  4. May 22, 2017 at 12:30 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Just buy an OR recovery hook which you can put in place of the factory tow tie down. That is what I did.
    THey will pop up every now and then on here.
    TireFire likes this.
  5. May 22, 2017 at 1:00 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Do you have a tow hook or are you talking about the tie-down loop?
  6. May 22, 2017 at 1:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Asking the real questions here.
  7. May 22, 2017 at 1:24 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Something interesting from the owners manual. It shows on sport and SR5 models to use the welded loop as the tow point, and on off-road models it says to use either/both.
    Sidney Vicious likes this.
  8. May 22, 2017 at 1:48 PM
    winguyen
    winguyen Well-Known Member
    Kevin
    Watertown, MA
    2014 Pyrite-Mica DCSB TRD Off-Road
    Tow points are not the same as recovery
  9. May 22, 2017 at 1:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    He is aware, but those are what OP is referring to.
    IronPeak likes this.
  10. May 22, 2017 at 1:54 PM
    akkyle
    akkyle Well-Known Member
    Kyle
    Alaska
    2014 regular cab 4x4
    if it means anything, I have recovered a 2011 double cab toyota tundra that was up to its running boards in clay using the emergency towing hook by the "tugging" method (gain speed, let chain transfer that energy into the other vehicle, repeat)...
  11. May 22, 2017 at 1:55 PM
    winguyen
    Kevin
    Watertown, MA
    I don't know, judging from the OP's post it looks like he was curious about using it as a recovery point
  12. May 22, 2017 at 1:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh I see what you mean now. I think what he's saying is that for the occasional light recovery, they're fine aka barely stuck in the sand. Anything more would require proper recovery points.
  13. May 23, 2017 at 2:56 PM
    IronPeak
    AuggieX
    Back to Back
    Off-road Hook for sale
    https://www.tacomaworld.com/threads/fs-various-05-11-stock-parts-bed-basket.492769/
