Would I be doing more harm than good
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joel561, Feb 15, 2021.
  1. Feb 16, 2021 at 3:24 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Another sock........... :rofl::rofl::rofl::rofl:
    Pelicans UNITE
  2. Feb 16, 2021 at 3:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Just to be terminology clear, your transmission does not use an oil, it uses a transmission fluid.
    While it is liquid, it has a very different chemical composition than oil.
    I mention this because if you are in a parts house, some of the keyboard jockeys might get flustered and bring you the wrong stuff.
    BTW, I support the method @Key-Rei suggests. Have done it several times on high mile vehicles with great success.
    And yes, your trans has a filter that should be replaced. If your current fluid is still pretty pink/red and smells decent, I'd wait and do it right before your last drain/fill. If the current fluid is dark or has some stink, I'd do it with the first drain/fill.
    Joel561[QUOTED][OP] and Key-Rei like this.
  3. Feb 16, 2021 at 3:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Key-Rei likes this.
  4. Feb 16, 2021 at 3:56 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I hit 190k. I just did the fluid change for the second time. My mechanic said my old fluid didn’t appear that dirty.
    Joel561[OP] likes this.
  5. Feb 16, 2021 at 3:58 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Joel561[OP] and TnShooter like this.
  6. Feb 16, 2021 at 5:00 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I did a drain and fill , and dropped the pan also at 120k and mine shifts smoother afterwards . I thought it was ok before the drain and fill but after there always a noticeable difference
  7. Feb 16, 2021 at 5:01 PM
    igno1tus
    :rofl:
    That’s funny shit
  8. Feb 16, 2021 at 6:52 PM
    Knute
    You positive sure about this??????
  9. Feb 16, 2021 at 6:59 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    I think they unwatched...
  10. Feb 16, 2021 at 7:08 PM
    Knute
    No surprise.
  11. Feb 16, 2021 at 9:54 PM
    Waasheem
    Waasheem
    2007 xrunner
    Is being called a pelican like being called a fiddlin ben or closer to a chisler?
  12. Feb 16, 2021 at 10:04 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Who shit in your cereal, man? There most definitely is a wire mesh filter in there.
    It can be cleaned but is kinda a pain and replacement is cheap. Wouldn’t recommend RTV here just get the gasket. Also, doing multiple drain and fills is a waste of time, unless you’d be watching Fucker Carlson on the tele otherwise haha. Doing a proper flush where you first drop the pan and then use the transmissions own pump is pretty easy and replaces all the ATF in one go.
  13. Feb 17, 2021 at 9:16 AM
    igno1tus
    agree also , but just emphasize the use of the transmissions own pump and not a actual flushing machine . Op might miss that possibly
  14. Feb 17, 2021 at 9:30 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    Or would you want to change the filter after the flush so you don't get old contaminates into your new clean filter?
  15. Feb 17, 2021 at 12:06 PM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    Good thought.
    Last para, post 22.
    IMHO of course.
  16. Feb 17, 2021 at 12:25 PM
    #36
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    I have an '06 with 170k miles on it, unknown to me if the previous owners ever drained it but I would be surprised. I am not having any symptoms whatsoever from my transmission. Do you guys think it would be worth it to drain and replace the fluid and filter as preventative maintenance?
    Any suggestions for transmission fluids that can handle temperatures that get down as low as -50F in the winter and as high as 90F in the summer? Also, looking at Rock Auto there's a lot of brands to choose from for filters, is there an aftermarket brand that you'd recommend?
  17. Feb 17, 2021 at 6:30 PM
    #37
    Knute
    Wix is known for good filters.
  18. Feb 17, 2021 at 8:40 PM
    #38
    racerX969
    racerX969 Active Member
    I did the drain and fill on my 07 at about that mileage, has 313k now, never got over a 100 deg. at -6 this morning on my 20 mi. trip to work.
  19. Feb 17, 2021 at 8:43 PM
    #39
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Nice mileage there, congrats! Did you swap the filter too? What did you put in for ATF?
  20. Feb 17, 2021 at 8:56 PM
    #40
    racerX969
    Toyota fluid, no filter change. Another month or so will be doing about a 1000 miles a week.
    Yukon DoIt likes this.
