Would these shocks not fit Toytec Coils?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mxer256, May 27, 2012.
  1. May 27, 2012 at 9:31 PM
    Mxer256
    Mxer256 [OP] Well-Known Member
    Tyler
    Mississippi
    2012 Prerunner
    2012 Tacoma Trd sport, 10" bulletproof lift with traction bars and icon resi rear shocks, custom headlights and tail lights, 24x14 American force jades,37x13.50x24 Toyo mt, 1" borla wheel spacers, 30" lightbar, new build so more to come come
  2. May 27, 2012 at 11:52 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
  3. May 28, 2012 at 10:55 AM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
  4. May 28, 2012 at 1:31 PM
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    If you go with the 5100's they are about 50 bucks more and you can get the discount code DSM gives for TW members. If you get the coils and the 5100's you can adjust the 5100's setting to the second setting to get 3" 's of lift but going over 2.5" people recommend UCA's for alignment purposes. (correct me if I'm wrong on the alignment part)
  5. May 28, 2012 at 5:39 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    So even if i do get that set up i wouldnt be able to get 3 inches without getting new UCA? Why would people be able to get a 3 inch spacer and not have to get new ones? but everything else does make sense and helps...also DSM?
  6. May 28, 2012 at 6:05 PM
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    Sorry DSM = down south motorsports. You can go the 3 inches since you are 2wd it's not recommended to go over 2.5" with 4wd due to cv angels. The UCA is for alignment purposes something about not getting the toe or camber to the right spot, if you dont your alignment will keep going off and will only cause tire wear. Sorry if I didn't explain myself right in my earlier post. Hope I did a little better job.
  7. May 28, 2012 at 8:10 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    OP has a 1st gen so setting the 5100's at stock setting will achieve 3". The pro comps are not as good as 5100's. No one that i know of has paired the pro comp's with the toytec coils. 1st gen does not require new UCA's at 3". although alignment will go out more often as said in an earlier post.
    EDIT: this topic should be researched by the OP as there are 100's more threads that have covered these lift components already.
  8. May 28, 2012 at 8:21 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    :D Great...guess i cant buy much more stuff now till i get this done. Thanks for the help!...and also how do i get that down south motorsports coupon or whatever?
  9. May 28, 2012 at 8:22 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    Ah alignment:rolleyes:.....but yeah i guess ill just have to go with 5100s
  10. May 28, 2012 at 8:32 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    I have them on my taco, its a great ride improvement over stock.
  11. May 28, 2012 at 9:17 PM
    Denim Dan
    Denim Dan Confusion
    Erick
    Visalia Ca
    96 4x4 reg cab
    click this link it has codes for some of DSM's products they sell. also you can lift if you dont mind having to do your alignment every couple of months i plan on lifting mine without UCA's till i get money for them and i only plan on about 2 inches of lift. also you can look into OME(old man emu) coils since those eibachs are sold out.
    this ^^^ ive heard. i was going this direction 5100's/OME 880's but ran across some coil overs for really cheap in the buy/sell/trade section. so i am going with those now, but have heard nothing but good things about 5100's with eibach and or OME's
