would uca's help?
Discussion in 'Suspension' started by quicksilvertacoma, Nov 6, 2009.
  1. Nov 6, 2009 at 6:10 PM
    quicksilvertacoma
    quicksilvertacoma [OP] Well-Known Member
    Harlingen, TX.
    08 Reg. Cab Tacoma 4x4
    NA
    Ive got a level lift on my truck which gives a little over 2' of lift. It might just be me but the tires dont seem completely aligned...would some all-pro uca's help this issue or not?
  2. Nov 6, 2009 at 6:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your better off with Camburg, Total Chaos, or Light Racing. Yes...they will help.
  3. Nov 6, 2009 at 6:18 PM
    quicksilvertacoma
    Harlingen, TX.
    NA
    Chris 4x4 one more question...thinking about taking the level lift off and putting 884's with billsteins. better setup or rougher ride on the reg cab? i just want the best lift around 2.5' without having to go to coil overs...
  4. Nov 6, 2009 at 6:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It would be more firm than stock, but better than the spacer lift. THe 5100's are leaps and bounds better shock than the OEM too.
  5. Nov 6, 2009 at 6:25 PM
    quicksilvertacoma
    Harlingen, TX.
    NA
    got ya. but would this get 2.5 of lift or a lil less?
  6. Nov 6, 2009 at 6:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im thinking 2.5" or more. You can get the 1/4" spacer to add more to it, if your getting the UCA's too...
  7. Nov 6, 2009 at 6:30 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    "Don't seem aligned" based on what?? Your eye, tire wear, or the numbers from an alignment rack report??
    Point of semantics...but 884 COIL SPRINGS OVER 5100s...are coilovers. Non adjustable- but coilovers non the less.
  8. Nov 6, 2009 at 6:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct ^^^^^^^^
  9. Nov 6, 2009 at 6:34 PM
    quicksilvertacoma
    Harlingen, TX.
    NA
    sounds good...now to decide, the eibach or ome coils...
  10. Nov 6, 2009 at 6:36 PM
    quicksilvertacoma
    Harlingen, TX.
    NA
    eye...and the wheel seems to pull a bit when im slowing down
  11. Nov 6, 2009 at 6:39 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    When was the last time you had it in for an alignment??
    Cause after the UCAs or the 884/5100 swap-it will need to be aligned anyways...but it may still come in without the UCAs...not positive it will...but it might work out.
  12. Nov 6, 2009 at 6:44 PM
    quicksilvertacoma
    Harlingen, TX.
    NA
    got aligned after i put the level lift and again after i put new wheels and tires on it a few months back. so twice in the last 8 months id say
  13. Nov 6, 2009 at 6:45 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    new wheels and tires dont require a alignment
  14. Nov 6, 2009 at 6:48 PM
    quicksilvertacoma
    Harlingen, TX.
    NA
    i payed for a 6 month alignment deal so i took advantage.
  15. Nov 6, 2009 at 6:50 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    gotcha
