Would you do it?
Discussion in 'Suspension' started by Bearskill, Oct 18, 2009.
  1. Oct 18, 2009 at 2:51 PM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Ok, Im looking at getting the Pro Comp Trac Bars for my 2006 sport to help stop my driveline/axle wrap. The only thing is I have to drill a hole in my frame to mount the forward bracket. Knowing that the new Tacoma's frames are not the strongest, would you drill it? Or weld it? Or are there other options out there?
  2. Oct 18, 2009 at 3:15 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    welding it is alot worse then drillin a hole
  3. Oct 18, 2009 at 3:16 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    How so? Maybe just because I am studying for my deforms exam, but I don't see how that would be true
  4. Oct 18, 2009 at 3:21 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I agree, how?
    I'm planning on welding on light tabs to my allpro tube bumper, but my gf insists that I just drill holes through it because I currently have no access to a welder. I don't want to affect the integrity of the bumper in any way...which drilling a hole half the diameter of the tube itself will probably do.
  5. Oct 18, 2009 at 3:26 PM
    Bearskill
    Sac
    I figured as much on the wielding, but how about the 7/8" hole being drilled, will it reduce integredy of the frame or not affect it?
  6. Oct 18, 2009 at 3:31 PM
    sachou
    Sam
