Would you trust this hub?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dcaplan, Apr 23, 2015.
  1. Apr 23, 2015 at 3:39 PM
    dcaplan
    dcaplan [OP] Well-Known Member
    Drew
    Fergus, ON
    2020 4Runner Venture
  2. Apr 23, 2015 at 3:40 PM
    Manwithoutaplan
    ID
  3. Apr 23, 2015 at 3:46 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Honestly, sounds like a cheap piece of junk. Search hub assembly here on the forum, couple members on here make them for our tacos. Help fellow members on here. Just my own opinion.
  4. Apr 23, 2015 at 3:53 PM
    dcaplan
    Drew
    Fergus, ON
    Thank you, I appreciate it. I am a little torn on the issue (not which hub to buy) but whether it is even my issue. I have a little bit of top/bottom play in my wheel which tells my ball joints but the issue is that at low speeds I get a low humming noise that makes my truck sound like it is revving high. I put brand new tires on today thinking it was cupped tires (I was due for new one anyways) but the sound is still present. I am thinking wheel bearing but I have been wrong in the past about other things and this sound is new to me.
  5. Apr 23, 2015 at 4:32 PM
    dcaplan
    Drew
    Fergus, ON
    I think I just confirmed my thinking, if I turn right the sound goes away. I have just never had a wheel bearing go that isn't really loose but just hums.
  6. Apr 23, 2015 at 6:08 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    get what you pay for.... no way id want a cheap hub holding the front tire onto my truck.
  7. Apr 23, 2015 at 7:20 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    I would've changed both sides at the same time. You wouldn't have this issue if you did.
    And yeah, stay away from dem Chinese parts.
  8. Apr 24, 2015 at 2:53 AM
    dcaplan
    Drew
    Fergus, ON
    Fair enough, I have sent a PM to the guys on this forum to see if they will ship to Canada. If not I will just go the press and replace route again.
