wrap warranty and steering bushings!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman06, Aug 31, 2008.
  1. Sep 18, 2008 at 2:48 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    actually, the tires are a new set that they put on when i got the truck....nothing wrong with them except they arent an a/t tire at all.:rolleyes:(which was what i asked them to put on........i guess cause the tire says "cross country",they figured it'd work.) the steeing issues are solely in the rack bushings being worn out...and they cant get just the bushings, so they have to get the entire rack...which is like$1350............good thing i got the wrap warranty.
  2. Sep 18, 2008 at 8:25 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    cool you got it worked out & found a good tech on your side, no reason you should have to take the hit moneywise especially with the warranty. Beers all around well soda for me. :drunk:
  3. Sep 18, 2008 at 8:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    pepsi for you!!!:D corona's for us!!
  4. Sep 19, 2008 at 9:06 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Well good deal....
  5. Oct 13, 2008 at 12:47 PM
    Choco Taco
    Choco Taco Sprayin' Paint like Its my Job
    South Dakota
    01 D-CAB SR5
    2" Lift 265/75/16' MT's Homemade Prerunner Bar
    A little off topic, but I know my rack bushings are shot (leak fluid everytime i turn), and I looked it up on All-Data, cant seem to find anyhting about just replacing the bushings, I'm a do-it-yourselfer so I was hoping I wouldn't have to replace the whole rack
    Can just the bushings be replaced?
  6. Oct 13, 2008 at 12:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well...if fluid leaks out every time you turn the wheel...you have more to worry about than bushings. sounds like your rack has bad seals too. but yes....the rack bushings can be replaced............but you cant get all them thru the dealership. you need to get them from energy suspension, wheelers offroad, or toytec. the bushing kit isnt all that expensive, and shouldnt be all that hard to do. here is a link on how to replace those bushings......
    http://www.parksoffroad.com/tacomamods/kristacoma/rackbushings/rackbushings.htm
    and another link.....
    http://4x4wire.com/toyota/maintenance/steering_bushing/
  7. Oct 13, 2008 at 1:13 PM
    Choco Taco
    South Dakota
    01 D-CAB SR5
    thanks, I'll give it a try, hopefully its not just a bandaid fix, cuz I cant afford a new rack right now
  8. Oct 13, 2008 at 1:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hopefully...it will take care of the problem. you may want to add some power steering stop leak to the reservoir also, and replace the bushings...........becasue a new rack is really expensive. im thankful that i bought my wrap warranty, because if not....i wouldnt have been able to afford the rack.
  9. Oct 14, 2008 at 1:00 AM
    Choco Taco
    South Dakota
    01 D-CAB SR5
    yeah.... I gotta do my TRE's soon so I might as well do the bushings while I'm at it
  10. Dec 17, 2008 at 9:01 PM
    busatodd
    busatodd BUSATODD
    whiteland
    2016 limited mgm
    3rd gen 5100 bilstiens set at 0 with ome 888s, LR UCA, 5160 bilstiens in back with icon 3 leaf aal with 1" block. Fuel savage wheel wrapped in nitto ridge grapplers 285/70/17
    sucks you had to go through all that to get fixed what should have already been fixed! i was going to suggest going to a personal mechanic and have them look it over and give you an estimate, then take it back to dealership and ask them if its STILL NORMAL!!!!
  11. Dec 17, 2008 at 9:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah man..............it was a pain in the ass for a while, but im glad i finally got it squared away.
