Wrenching on a slight slope
Discussion in 'General Automotive' started by pontoon, Feb 12, 2018.
  1. Feb 12, 2018 at 9:59 AM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    My current driveway is sloped down slightly. It’s enough that the truck will slowly roll forward if I let off the brakes in neutral. Chick the wheels, use jack stands, and go for it? Or should I find a flat spot to work?
  2. Feb 12, 2018 at 10:01 AM
    la0d0g
    running for the hills
    For crawling not hauling
    How much do you value your life?
    shakerhood and scottalot like this.
  3. Feb 22, 2018 at 6:14 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Depends on the work. If the rear tires stay on the ground, you have triple-redundancy:
    1. Transmission in gear
    2. Parking brake
    3. Tire chocks
    I have been doing oil changes on my Subaru on a slightly inclined part of the driveway for seven years. It's an automatic so the transmission is in 'P' with the locking prawl. The parking brake works. And the tire chocks are 6" tall urethane: https://www.amazon.com/gp/product/B0052PVRDW/ I use two pairs so each rear tire is chocked in both directions. For work that requires lifting the whole car up on four jack stands, I move the Taco out of the carport and bring the Subaru inside.
  4. Feb 22, 2018 at 6:17 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    Only "Chick" the wheels if you are tired of her bullSh**T
