Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Oct 20, 2011 at 2:43 PM
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Okay so I figured I'd make this now, to start informing people as I learn and figure it out.
    I bought:
    5$ - "Torque Pro" App for my Android (Galaxy S2) phone
    https://market.android.com/details?id=org.prowl.torque&hl=en (There is also a free version of this app called "Torque", just has less features.)
    20$ - ELM327 OBDII Bluetooth reader
    http://www.hoyasource.com/hottest-bluetooth-elm327-odb-ii-2-canbus-scanner-tool-p-75.html
    (Remember to unplug the reader when vehicle is not in use as I noticed it stays lit up so it is still drawing power)
    So as it sits right now you can have this system for dirt freaken cheap, I say its worth it.
    It so far kicks ass, I now have access to all the values being read in my Taco, and being that this is a universal system, I can plug and play it into any vehicle made post 1997 (When they standardized to OBDII). If the vehicle measures more values, then more values show up on my phone. It can show me Mileage, speed, gps tracking, intake temp, coolant temps, AFR's, tranny temps (If your an auto), the list goes on and on. There is a way to measure HP and Torque on it too. Still learning because its such a broad device.
    OP will be updated as I figure more shit out. Any questions just ask!
  2. Oct 20, 2011 at 2:46 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ***Straight from their website***
    Measure Torque, BHP & 0-60
    Clear car OBD faults
    View engine data in Google Earth
    See what your car is doing in realtime, get OBD fault codes, car performance, sensor data and more!
    Torque is a vehicle / car performance / diagnostics tool that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU
    Layout your own dashboard with the widgets / gauges you want!
    It can use the GPS to provide tracker logs with engine logging so you can see what you were doing at any point in time
    It can also show and reset a DTC / CEL / fault code like a scantool.
    Torque also features:
    * Dyno / Dynomometer and Horsepower/HP & Torque
    * Can read Transmission Temperatures (vehicle dependant)
    * 0-60 speed timings – more accurate than just using plain old GPS – see how fast your car is (or truck [​IMG] )
    * CO2 emissions readout
    * Customisable dashboards
    * Video your journey using the Track Recorder plugin with onscreen OBDII data overlay – a black box for you car/truck!
    * Automatically send GPS tagged tweets directly to twitter (for example if you are going on a road trip)
    * Massive fault code database for allowing lookup of fault codes from many different manufacturers
    * Theme support (choose from different themes to change the look of your dashboard)
    * Send logging information to web or email CSV/KML for analysis via excel / openoffice
    * Heads up display / HUD mode for night time driving
    * Compass (GPS Based) that won’t suffer magnetic interference
    * GPS Speedometer/Tracking and realtime web upload capability – see what you were doing and your engine, at a point in time
    * Turbo boost feature for vehicles that support MAP and MAF sensors (VW / Audi / Seat etc supported)
    * Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
    * Car dock support
    * Graph data
    * Able to share screenshots to Facebook, Twitter, Google+, Email, etc
    * AIDL API for connecting third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
    * Works on tablet devices like the Motorola Xoom, Dell Streak, and Samsung Galaxy Tab
    Works on any vehicle that uses the OBD 2 standard (most vehicles built after 2000, but can work for vehicles as far back as 1996) – if in doubt check with your manufacturer first or look for ‘OBD2′ on written on a big white label in your engine bay
    Works on vehicles made by Ford, GM/Vauxhall/Opel, Chrysler, Mercedes, Volkswagen, Audi, Jaguar, Citroen, Peugoet, Skoda, Kia, Mazda, Lexus, Daewoo, Renault, Mitsubishi, Nissan, Honda, Hyundai, BMW, Toyota, Seat, Dodge, Jeep, Pontiac and many more vehicle makes, European, US, Far East, etc. Some vehicle ECUs may support more/less features than others.
    The app needs a Bluetooth OBD2 adapter to work. The adapter is small and plugs into the diagnostics socket on the car which gives your phone access. You can find a list of adapters on: http://torque-bhp.com/wiki/Bluetooth_Adapters (Garmin EcoRoute HD adapters not supported).
    If you buy one of the cheap china OBD2 ELM327 bluetooth adapters from ebay / Amazon, then make sure you have a good returns policy with the seller as quite a few of the cheap units are defective and ‘stop working’/etc.
    Some of the best reliable OBD2 / OBD adapters are the Scantool.net adapter, the OBDKey adapter, and PLX Devices Kiwi Bluetooth, ELM327 and other ELM adapters are supported – search on google for them
    More features added every release – there are forums at http://torque-bhp.com/forums/ – if you want something added then let me know and I’ll try to add it if it is possible! Vehicle ECUs vary in the amount of sensors supported
  3. Oct 20, 2011 at 2:54 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    16$ is for 10 or more, its 20$ for one
  4. Oct 20, 2011 at 2:55 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Interesting, I wonder if it's better then my Ultra-Gauge
  5. Oct 20, 2011 at 2:56 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Well, I know the website lists about 60 diferent values but our Taco's only measure probably 35-40ish of them. I want to make an actual list of what is monitored for us and I'll post it up.
    Thx for the heads up, OP changed
  6. Oct 20, 2011 at 3:00 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I think it is most definitely more user friendly (Its colourful and flashy, I like flashy) but I've never owned a UG so not sure how it compares.
    images_5b831e9b504353bae1cea6f458a2737832dc5e4c.jpg [​IMG]
    Also, all of those can be customized, I can change what gauges I want to read, change the sizing and the guage type too. Like for example, I can have just the RPM Gauge anything from a needle gauge, bar gauge, bar graph, scatterplot graph, straight up digital readout. I can change background skins too!
    There is also tilt and roll gauges for you offroading types, or those of you with the intentions of flipping your car.... *cough lilredstud cough*
  7. Oct 20, 2011 at 3:04 PM
    Burgman
    Stephen
    Ric VA
    hmmm, buying now
    that website wanted over 20 bucks for shipping
    looking on ebay now, ebay sucks lost interest in purchase
  8. Oct 20, 2011 at 3:50 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  9. Oct 20, 2011 at 3:54 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Can you verify for sure that you can read the transmission fluid temps with that thing? If so I'm going to let the folks at Linear Logic know (Scan Gauge II) so they can learn something lol
  10. Oct 20, 2011 at 3:55 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I don't own an automatic tacoma but i do live near the dealership, i'll stop by on the way to work and find out
  11. Oct 20, 2011 at 4:23 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I should be able to start to play with mine this Saturday. I believe the shed I am building will be finished tomorrow. THX for the heads up on this combo. The entire set up cost less than a lot of the basic code readers that are out there.
  12. Oct 20, 2011 at 4:32 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yup, and my favourite part, 100% universal to any vehicle and Torque app auto internet updates and full support. Had it 1 day and already read a code on my buddies jeep for him
  13. Oct 20, 2011 at 4:35 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
  14. Oct 20, 2011 at 4:37 PM
    SCFirefighter
    Stephan
    Cary, NC
    FYI you should also be able to use these Bluetooth dongles with certain Garmin receivers and get performance and mileage data into your Garmin.
  15. Oct 20, 2011 at 4:39 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Just purchased the "Track Recorder" add on for the torque app, and by purchased i mean downloaded and installed for free. I'll let you know how it works
  16. Oct 20, 2011 at 4:40 PM
    Commie
    Commie Well-Known Member
    G
    Hanford, CA
    TRD Off-Road
    SCS F-5 Black with BFG AT 265/75/16, 2.0 Radfls's w/ top plate, LR UCAs, TSB springs w/ 5160, rear diff breather, blacked out grill/ emblems/ rear bumper/ lower valance, LED map/ dome/ lic plate lights, switchback DTRLs, anytime fogs, WeatherTech DigitalFit liners
    Is there an app for the iphone or just android?
  17. Oct 20, 2011 at 4:42 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Android only for right now, I think it only came out in early Sept. I'm sure ones in developement its stupid popular on the market right now
  18. Oct 20, 2011 at 4:45 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Man thats really neat, I wish they would come out for one for the iphone. Or maybe i need a droid:anonymous:
  19. Oct 20, 2011 at 4:56 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Pssh I was using torque before it was cool
    imagesqtbnANd9GcRGBqi2sO7sODNAy32mKAg1TA_3c98e0a32fcac797c00791684b56118a986587ef.jpg
    I have an inactive OG droid so it just does full time torque duty in the truck. I bought a windshield mount for it off ebay but the suction cup quit sucking so I modified it... I'll take a pic when I go to dinner. I'll also check to see all the sensors that have data for 1st gens.
  20. Oct 20, 2011 at 5:05 PM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Can this actually read AFRs for our trucks?
