Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Jan 9, 2012 at 11:53 AM
    #181
    psychohamster
    psychohamster Active Member
    San Diego
    09 4x4 SR5
    IVD remote res coil-overs, Total Chaos UCAs, ARB Deluxe Bull-Bar, Warn 9.5XP, Luna Dual-Battery Controller
    Had good luck watching them side-by-side this morning - B rose faster and generally stayed a little higher than A, which is what we would expect based on the sensor positions. Values seemed stable - didn't fluctuate quickly.
    Think we've got this figured out!
  2. Jan 10, 2012 at 2:50 PM
    #182
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Did you have any luck with the diagnostic mode comparison?
  3. Jan 11, 2012 at 12:06 AM
    #183
    biborado
    biborado Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
    I did manage to try this out. It is a bit tricky since you can only do one or the other. But I did manage to put it in diagnostic mode and went back and forth from that to the obd dongle. Using the torque app I was able to verify that the temperatures being reported were reasonable and seemed to correspond to the 115°F and 130°F activation points.
  4. Jan 11, 2012 at 6:18 AM
    #184
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Those pid's didnt report anything for my +06 :(
  5. Jan 11, 2012 at 2:52 PM
    #185
    LGE RAW
    Rob
    Dothan
    Did you use the 21D9 PID equation below?
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 1
    Short Name:
    TFT 1
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    °F (there is a degree symbol in Torque)
    Equation:
    ((((E*256)+F) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    For sensor 2 (Converter outlet temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 2
    Short Name:
    TFT 2
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    Equation:
    ((((G*256)+H) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    scocar and Durnaia like this.
  6. Jan 11, 2012 at 5:13 PM
    #186
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I changed it to the 21d9 while i was at work. That did it :eek:
  7. Jan 12, 2012 at 6:04 AM
    #187
    LGE RAW
    Rob
    Dothan
    Sweet success!
  8. Jan 12, 2012 at 6:12 AM
    #188
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Yep! Thanks
  9. Jan 12, 2012 at 11:56 AM
    #189
    Sabre
    Sabre Well-Known Member
    Kyle
    Silverdale, WA
    2014 F-150 FX4
    Guys I'm having trouble pairing the obd2 to my app any troubleshooting I can do I bought the Bluetooth one off Amazon
  10. Jan 12, 2012 at 12:22 PM
    #190
    Sabre
    Kyle
    Silverdale, WA
    2014 F-150 FX4
    Nvm I got it
    Not sure I'm setup entirely right though gotta mess around with it
  11. Jan 12, 2012 at 12:56 PM
    #191
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Man all these equations! Sex for my brain! Too much info-ma-shuns! But thanks guys now I can calculate the angle of the dangle :)
  12. Jan 12, 2012 at 2:24 PM
    #192
    LGE RAW
    Rob
    Dothan
    The cheap ones are known to be defective from the factory a lot.
    Not sure if there is much you can do. Post up what you are seeing when you try to pair it. There are several pin codes listed through this post. Does your phone even detect it when in discovery mode? Are there any LEDs on the dongle that indicate it is working?
  13. Jan 12, 2012 at 3:45 PM
    #193
    Aw9d
    Aw9d That one guy
    Big thanks to psychohamster and RuggedT for figuring this out. I was following the thread on torque forums and am amazed on how fast you guys got this working.
  14. Jan 13, 2012 at 10:35 AM
    #194
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I haven't found where the app even comes to a point for you to enter a PIN code. Would this mean there is not one set up on the device if not asked to enter a code? Usually is the case with other stuff. It does connect and run but hasn't ever asked me for the pin.
  15. Jan 13, 2012 at 10:48 AM
    #195
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    You need to buy the real version. Free dosnt allow custom PID's
  16. Jan 13, 2012 at 11:04 AM
    #196
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I do have the full version. I'm not talking about PIDs, I'm talking about entering the PIN for the bluetooth device.
  17. Jan 13, 2012 at 11:13 AM
    #197
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Gotcha... You do that from the phone itself. Not from the Torque app.
  18. Jan 13, 2012 at 11:35 AM
    #198
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    OK, neither the phone nor the app has asked..............that's why I can only assume the bluetooth device does not have one set up. And what if I wanted to change it from something besdies 0000 or 1234 or 6789? No place to do that either.
  19. Jan 13, 2012 at 12:23 PM
    #199
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Android or Crapple?
  20. Jan 14, 2012 at 6:53 AM
    #200
    LGE RAW
    Rob
    Dothan
    Plug it it and place your phone in discovery mode and also scan for devices. Not all of the bluetooth devices ask for a pin. My Kiwi did, as did my Plantronics head set. If the device is working, it should show up under bluetooth devices. When you get to that point, start Torque and turn your ignition on so that Torque and your ECU will communicate and sync. look under settings to set it up as needed.
