Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Feb 24, 2012 at 9:18 AM
    #221
    Aw9d
    Aw9d That one guy
    Sounds good in theory.. I don't have bigger tires to test this out with but I have all the software if anyone in Phx wants to figure it out.
  2. Mar 3, 2012 at 7:09 PM
    #222
    lordmdp
    lordmdp New Member
    Hey Guys! Still having trouble with mine
    I finally got the Droid razr to find and read my obd2 bluetooth dongle but the dongle doesn't read anything from the truck(or torque doesn't read anything) i dunno--im not good with this stuff but I do learn fast
    it asks me if the ignition is turned on(which it is everytime---any help!?
    i'm desperate enough i'll paypal someone a few bucks of they help me and i'm able to get this to work!
  3. Mar 4, 2012 at 11:28 AM
    #223
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Is torque syncing to the dongle? It should sync to the dongle when you start torque with the ignition on. you may have to go to Torque settings and select the dongle to use. There should be four icons on the main screen that show sync to the satellite for GPS, the phone, the the dongle and the ECU. Those may not be exact but close.
  4. Mar 5, 2012 at 7:49 PM
    #224
    lordmdp
    lordmdp New Member
    Yes--i got that connected
    but then after 30 seconds it says the dongle can't read the ecu
    UPDATE: it worked on our 98 4.3l chevy blaser
    wont work on our tundra or tacoma?
    wtf!?
  5. Mar 6, 2012 at 4:08 AM
    #225
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mine does that shit too where you have to go into setting and fuck with it to get it to hook up. Kind of annoying. Shouldn't have to pair it up everytime you use the damn thing.........and yeah, saved the profile while it was working.
  6. Mar 6, 2012 at 5:31 PM
    #226
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    My OBD2 scanner came today and I already have the full version Torque app. Got them paired tonight and started to play. Amazing what kind of info you can get for < $20.00 investment!!!
  7. Mar 9, 2012 at 2:49 PM
    #227
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Got mine paired up a week or so ago, just added the Transmission temp based on the formula provided here.
    Thanks for the help!
  8. Mar 10, 2012 at 6:51 PM
    #228
    Fightnfire
    Marysville, WA
    My tranny temps are running 145 (cruising freeway at 65)-165(accellerating on freeway or city), that sound about right? Also, coolant is at 180ish.
  9. Mar 10, 2012 at 7:37 PM
    #229
    LGE RAW
    Rob
    Dothan
    That sounds about right. Your transmission cooler will help hold those tranny temps down unless your pulling a load.
  10. Mar 12, 2012 at 7:08 PM
    #230
    gusher
    Greg
    Hudson NH
    Just added the PIDs for transmission temp and am looking forward to checking them out tomorrow. I created a new view with the trans temp and a few other temps but all of the canned ones are in degrees Celsius even though I set degrees Fahrenheit in the Torque settings. Anyone else see this???
    Also, is there a way to monitor oil pressure???
  11. Mar 12, 2012 at 8:07 PM
    #231
    LGE RAW
    Rob
    Dothan
    I've had some issues with the temp units and switched a couple of times then killed the app after exiting. seemed to come back correct then.
    As far as i know, the oil sending unit is a pressure switch and is on/off only. No way to get pressure range from it. If anyone else knows something different share it and we will get a PID built for it.
  12. Apr 3, 2012 at 9:57 PM
    #232
    sernaj64
    sernaj64 Aight
    Juan
    honolulu
    2011 prerunner V6 SR5
    N fab Step bars BHLM by Asianants Pro Comp 2.25" level lift kit rear leaf TSB
    how did you do it!!!!!! i can figure it out :confused:
  13. Apr 4, 2012 at 11:11 AM
    #233
    gusher
    Greg
    Hudson NH
    From the main Torque screen, you select "Settings" and then scroll down to "Manage extra PIDs/Sensors". From there you can "Add custom PID" and use the parameters spelled out earlier in this post.
  14. Apr 4, 2012 at 2:05 PM
    #234
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Kewl did it today, seems like its working. Thanks dewds!! TW is teh awesomeness!
  15. Apr 7, 2012 at 8:51 PM
    #235
    MainahWithaYota
    MainahWithaYota Well-Known Member
    Dallas, GA
    04 DC v6 4x4
    Anyone try using this thing on a 1st gen?
  16. Apr 9, 2012 at 9:34 PM
    #236
    MMazz365
    MMazz365 Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
    Anyone figure out how to make it recognize you have 33inch tires ??
  17. Apr 17, 2012 at 2:15 PM
    #237
    jjjewett
    jjjewett Member
    tahoe
    04 double-cab trd 4x4
    Sorry if this has been covered. I searched and couldnt find it.
    Is there a PID for 1st gen Trans temp?
    -JJ
  18. Apr 18, 2012 at 9:13 AM
    #238
    jjjewett
    jjjewett Member
    tahoe
    So I purchased the paid version of Torque and it does come with a ATF temp gauge. Sweet tool!
  19. Apr 18, 2012 at 10:39 AM
    #239
    sernaj64
    sernaj64 Aight
    Juan
    honolulu
    Sweet thanks ill try it today after work.
    another thing
    how do I get the mpg to read/work I have a 2011tacoma prerunner DC short
    one more thing
    any one that has a 2011 tacoma prerunner DC short what did you put in for your profile.
    I'm an idiot when it comes to things like this any and all help will be greatly appreciated
  20. Apr 18, 2012 at 7:50 PM
    #240
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    I love this app!
