Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Dec 11, 2012 at 6:35 AM
    #261
    junkman
    junkman Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    I just set this up, will test soon. Not sure if this works for the 5-speed manual?
  2. Dec 11, 2012 at 7:34 AM
    #262
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    This app is great. I've got the plx kiwi Bluetooth obd adaptor. It was expensive, around $120 from Amazon but well worth it.
    Doesn't give me any bugs, and has a really fast refresh rate. I use it to data log my car, monitor IAT's, KR, AFR, etc. It's also fast enough to data log auto cross runs with the trackmaster app. The only real limitation is the accuracy of the my phones GPS receiver (motorola Atrix HD).
    Well worth the cost imo for something that can see any PIDs the ecu does, clears codes, etc. And for $5 or whatever it costs now even if you get the expensive adaptor like the kiwi it's worth it.
  3. Dec 11, 2012 at 9:50 AM
    #263
    junkman
    Erik
    Louisville
    OK, just tested these-
    For TFT1: I am getting some bizarre results - very volatile and sometimes going from very high numbers say 390 to very low, even negative numbers like -40 in an instant. I don't think this is a useful PID as configured at least for the 5 speed manual.
    For TFT 2: Getting what appears to be much more reasonable numbers. When first starting the figure was like 68 which is possible (although it is colder here than that, maybe there was some residual heat from 4 hours before. The number climed to 138 and was very stable in a short test drive. It eventually went to 138.1 then 138.2.
    Anyone have any input on these 2 PIDS?
    Is 138 a reasonable number for TFT?
  4. Dec 11, 2012 at 9:53 AM
    #264
    Aw9d
    Aw9d That one guy
    This is how it works for me as well. TFT1 is useless, TFT2 gives me data.. I'm pretty sure its working good, as when I towed it climbed up a lot. Typically I sit around 140 when just driving around.
  5. Dec 11, 2012 at 10:11 AM
    #265
    junkman
    Erik
    Louisville
    OK, thanks for the input. :cheers:
    I wonder if TFT 1 is the correct sensor but wrong math involved?
    Like what does the F stand for and why is it H in the second PID? Seems like the formula should be the same perhaps and the F is a typo?
  6. Dec 11, 2012 at 10:29 AM
    #266
    junkman
    Erik
    Louisville
    Or should I be using the 2182 pid as I have a 2013 truck, instead of the 21D9?
  7. Dec 11, 2012 at 10:32 AM
    #267
    Aw9d
    Aw9d That one guy
    The ECU and PID's should be the same from my 2011 and your 2013. I'm really not sure, you can try and and see if it works.
    I know TFT1 never has worked right for me. I don't even have it installed anymore.
  8. Dec 11, 2012 at 12:18 PM
    #268
    junkman
    Erik
    Louisville
    Yeah, well I tried all the variations on this thread and not sure any work for a 5-sp manual, or if they have temp sensors in the manual at all.
    The only one that seems remotely likely is TFT2 but the number is so stable on that at 138.0 138.1 or 138.2 max that it is hard to believe it could be correct. The other PIDS just jump around too much to be possibly correct.
    That said the program is super cool and plenty of other numbers are working.
    I want to try the trip set-ups, data logging and mapping stuff when I get a chance.
    It will also be interesting to see if the MPG calculations are accurate.
  9. Dec 12, 2012 at 3:39 PM
    #269
    Manwithoutaplan
    ID
    will this work for manuals as far as the reading the trans temp??
  10. Dec 12, 2012 at 3:41 PM
    #270
    Aw9d
    Aw9d That one guy
    Try towing something. My trans temp goes up a lot when I tow, but otherwise stays pretty much the same.
    As for MPG's, you have to tweak it a bit but between fulley, basic math, and a scan gauge my Torque app is about the same values.
  11. Dec 12, 2012 at 4:28 PM
    #271
    junkman
    Erik
    Louisville
    Yeah, I see now that there is a way to adjust the MPG figure.
    THanks!
  12. Dec 17, 2012 at 1:45 PM
    #272
    BackCountry
    BackCountry Well-Known Member
    2001 TRD
    Just scored one of these cheapie bluetooth OBDII devices thanks to the suggestion of another forum member. I can confirm that it connects with my 2001 Tacoma TRD. I was able to read the last error code, which is awesome. Hopefully I won't have to read error codes for some time now, but it looks like there are lots of other things I can do with torque in the meantime.
    Just curious what people are using their scanners for other than reading error codes and checking component temps? The MPG calc sounds interesting, but I'm unlikely to always run the app every time I go for drive.
    Very cool stuff, I feel so empowered to be able to read my own engine codes! :)
  13. Jan 2, 2013 at 6:32 PM
    #273
    RDNK TAZ
    RDNK TAZ Well-Known Member
    Chad
    Marion, SC
    '11 Silver Streak Mica DCSB TRD 2x4
  14. Jan 4, 2013 at 8:47 PM
    #274
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    subscribed :thumbsup:
  15. Jan 26, 2013 at 3:46 PM
    #275
    Vikkz
    Vikkz Member
    i have been using this for over a year, its nice to have this tool and if something comes up you can catch it real quick. BTW how do you tweek it so it can give you correct MPG and HP
  16. Jan 28, 2013 at 4:15 AM
    #276
    yellowrubiu
    yellowrubiu Well-Known Member
    Empire State
    2012 DCSB 4x4 SR5
    I have the Android version for my google phone but I really wish this was made for the iPad. This would be awesome with the screen size on my iPad mini.
  17. Jan 29, 2013 at 10:00 AM
    #277
    grizzlygoalie
    grizzlygoalie Active Member
    Littleton, CO
    2013 Tacoma TRD Sport
    I saw someone actually mounted an ipad in their dash to control their radio and such - made it look really nice with modding the bezel, had it running the app on half the screen - looked cool I'll have to find some pics
  18. Jan 31, 2013 at 4:47 PM
    #278
    Duncandiver
    Duncandiver Member
    Ordered a super mini ELM327 yesterday on Amazon. Up and running in a week or two.
    hehehe can’t wait.
  19. Jan 31, 2013 at 6:47 PM
    #279
    RDNK TAZ
    Chad
    Marion, SC
    I'm wondering since this uses an app to blue tooth to a phone or tablet, can the same go for one of the new app radios?
  20. Feb 12, 2013 at 4:50 AM
    #280
    douglasmc
    douglasmc Active Member
    Ga
    2013 tacoma sport 4x4 V6
    Fog light mod, 12 volt power full time, inverter 400w full time, Added 115v outlets in cab, Trimmed off 4in from front mud flaps, more to come ;)
    I sent a request into both Toyota and also ttorque about a month ago.. Neither has replied!!!
