Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Feb 12, 2013 at 7:52 AM
    #281
    grizzlygoalie
    grizzlygoalie Active Member
    Littleton, CO
    2013 Tacoma TRD Sport
    about what?
  2. Feb 12, 2013 at 10:49 AM
    #282
    douglasmc
    douglasmc Active Member
    Ga
    2013 tacoma sport 4x4 V6
    Fog light mod, 12 volt power full time, inverter 400w full time, Added 115v outlets in cab, Trimmed off 4in from front mud flaps, more to come ;)
    To see if an app could be made for entune
  3. Feb 12, 2013 at 12:34 PM
    #283
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Exactly what needs to be done to get the app to read out AFR? Id imagine the need for a wideband unless the Tacoma already uses wideband sensors?
  4. Feb 13, 2013 at 7:43 PM
    #284
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Torque is written for the Android operating system. If the APP radio is running Android, it should work.
  5. Mar 12, 2013 at 6:53 PM
    #285
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Heads up, I've had two separate OBD units fail on me from Amazon. both lived for 3-5 months.
  6. Mar 22, 2013 at 7:24 AM
    #286
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I've had my bluetooth adapter for 3 months, no problems yet. Did yours just up and stop working suddenly?
    A question I have tried searching for and still haven't found an answer, for you torque app users:
    How do you record and save the readings? I've been keeping track of things like mpg's, fuel trims, afr's, etc but can't figure out how to get the app to save copies of these readings after each trip.
  7. Mar 22, 2013 at 7:42 AM
    #287
    Fightnfire
    Marysville, WA
    Yes, both times it just stopped working.
  8. Mar 27, 2013 at 9:56 PM
    #288
    kbraunphoto
    kbraunphoto mountain bike haulin' & off camping
    Kevin
    Atlanta, GA
    '15 Inferno Orange TRD Pro
    Just a few expensive & DIY things...
    subbed, had this setup for about a year, gotta read this thread. sure ill learn something.
  9. Apr 19, 2013 at 6:50 PM
    #289
    krafty11
    krafty11 Active Member
    Chicago area
    2011 DCSB T|X Pro
    Tube Steps, BAK F1, 4WD light, Pop&Lock
    I just ordered a Bluetooth module but use Windows Phone 8 not Android, does anyone have experience with either the "Dash" app or "AutoGaugeX" both look interesting but neither is as mature as Torque yet
  10. Apr 20, 2013 at 12:03 AM
    #290
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Eh, I guess ill jump onboard...................I blame chrisJx4
  11. Apr 22, 2013 at 6:29 PM
    #291
    PreRunning
    PreRunning Well-Known Member
    Clayton
    Missouri
    01 Lunar Mist Prerunner SR5
    Window Vents, Westin Bull Bars, Kenwood Deck, Kicker and Kenwood Door and rear Speakers, Alpine 660 RMS Amp, Twin Kicker 12 inch CompVR Series Subs, 265/75/16 Wrangler ArmorTrac Tires, Uhaul Towing package, removed mud flaps, Flowmaster 40, Cold Air.
    What module did you buy?
  12. Apr 22, 2013 at 7:07 PM
    #292
    kbraunphoto
    Kevin
    Atlanta, GA
    BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool
    The Soliport one has some known errors and incompatibilities.
  13. May 22, 2013 at 10:13 AM
    #293
    Zooriver
    Zooriver New Member
    Montana
    1995.5 Toyota Tacoma 3.4 V6
    Just got mind all set up and working on my 1995.5 Tacoma :thumbup:
  14. May 22, 2013 at 1:05 PM
    #294
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  15. May 31, 2013 at 1:04 AM
    #295
    skygear
    skygear                    
    Anyone posting screen shots of their gauge clusters?>
  16. May 31, 2013 at 4:58 AM
    #296
    PreRunning
    Clayton
    Missouri
    X2
  17. May 31, 2013 at 8:01 AM
    #297
    skygear
    skygear                    
    I am using the Latest Torque version 1.6.46? or something with a skin and the default gauges.
    Got the OBDLink MX Bluetooth adapter with the latest firmware too.
    I need to figure out the rest of the stuff. Like I have no fuel gauge on here. Or the real time MPG stuff. Also wanted the Voltage meter, Tranny temp, and similar .
    Custom PID's?
  18. May 31, 2013 at 9:51 AM
    #298
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    You can add all that stuff by picking a gauge type and then picking which value for it. I pick the all info one and gives me a readout of everything all on one screen.
  19. May 31, 2013 at 11:53 PM
    #299
    skygear
    skygear                    
    I watched the video. Thanks though. Funny enough, I had already selected a few gauges, and they were not customizable. That is what prompted the question.
    Post some of your screen shots! I'm using a nice theme already, but am curious to see what others have as clusters..
    I was thinking of a custom mount for my cell phone also. Since my phone has wireless charging, I was thinking of something right above the steering column. Similar to the gauge pod. Also, I would mount the wireless charger station to it and possibly one of those fancy infomercial green cellphone pad mounts. The green one.
    That way, I get in the truck, drop it behind the steering column and go. It would be in the same spot as the gauges, so it would not be a distraction. Even would work for Day driving.
  20. Jun 1, 2013 at 12:12 AM
    #300
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Ya lost me. Wireless charging green mats??
