Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Jun 1, 2013 at 12:49 AM
    #301
    skygear
    skygear                    
  2. Jun 1, 2013 at 3:45 AM
    #302
    skygear
    skygear                    
    Basically i want to rip the silicone green mat off the mount and put it on a charging pad. Then use a bracket to secure it to the area above the steering column.
  3. Jun 1, 2013 at 11:18 AM
    #303
    Muddog006
    Muddog006 Member
    Having issues getting the MPG quite right.. 1st day with it in it reads 33 MPG..I'm like no this can't be right. So I play with it some and by day 2 I have 11 MPG showing up after about the same distance of driving. Seems it will take some time to figure out. It paid for it's self the 1st time I used it to trouble shoot Mom's Frontier. Darn thing had knock sensors and O2 sensors freaking out. After clearing the codes It seems she does have a bad O2 sensor.
    Anyways I spent 12 bucks on the adapter from a site called DX bunch of Chinese junk on the site. Who knows how long it will last, so far I like it enough to buy a new one of better quality.
  4. Jun 1, 2013 at 12:03 PM
    #304
    skygear
    skygear                    
    I haven't messes with mine too much other than the initial setup. I have it setup and recording when I get in the truck but I'm always busy when I get in the truck. Need to take a few hours and dedicate it to the app.
  5. Jun 6, 2013 at 4:58 PM
    #305
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Got mine in today and made a profile for my truck and my wifes 07 rav4
  6. Jun 6, 2013 at 5:01 PM
    #306
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Enjoy!
    I don't know if anyones had this happen yet but my ELM 327 module just failed this morning. Lasted 2ish years, not bad I think.
  7. Jun 8, 2013 at 11:40 AM
    #307
    yota243
    E.J.
    north Alabama
    hey just wondering how accurate some of these reading are, like AFR's specifically. mine says its roughly 14.5 most of the time between 14.3-15.0 anyway, and when i coasting it pegs out at 18.15:1. I realize when coasting there isnt much fuel going into the system but there should also not be much air right? and 14.5 is pretty lean for all other driving isnt it, since i thought the 1gr was set a little rich from the factory.
  8. Jun 8, 2013 at 11:44 AM
    #308
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Most regular driving should be 14.7, that is normal, you don't want much more than that. During some forms of coasting, the fuel system actually shuts off completely, which will cause your AFR's to spike high like that. That is also normal.
  9. Jun 18, 2013 at 8:43 PM
    #309
    yota243
    E.J.
    north Alabama
    I have seen that u can add pids for other sensors and found the equation for injector duty cycle but its only for gm. Does anyone no any additional cool stuff to add on to this?
  10. Jun 18, 2013 at 8:46 PM
    #310
    YotaKid62
    YotaKid62 Dirty mall crawler
    Forrest
    North Dakota
    00 Tacoma TRD Sr5 5 speed
    Grey Wire Locker Mod, 3" coil spacers & custom leaf packs, 2" BL, Skyjacker rear nitro shocks, Monroe front gas shocks; 15" eclipse sub & 1400 watt visonik amp with Kenwood stereo, Billet Petals, Black Aries series Grille guard, ebay baja lights (unsure of brand)
    I have one of these and went and put the app on my kindle, only to discover I don't have a device that is Bluetooth capable and smart enough to have apps (my phone is old). Time to get me a galaxy. The app itself looks killer though! pretty much seems to replace a scanguage if its all its cracked up to be!
  11. Jun 18, 2013 at 8:53 PM
    #311
    skygear
    skygear                    
    Only real differences is the scangauge becomes a solid "CAR" fixture in there. With this being on on our phones, answering calls, navigation and such becomes interesting.
    I forget to turn Torque off sometimes when I leave the truck. I might suggest that they build up a feature in the app for it to auto kill after xx Minutes of the app being idle.
  12. Jun 18, 2013 at 10:06 PM
    #312
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I was thinking of using either my OG droid, or when I upgrade, using my droid3 as a display for boost and whatever this can read that the ultragauge cannot.
    I find it odd that this thing can pull more info from the same obd2 port
    than other gauges. Im happy bout it, but perplexed at the same time.
    Either way, thanks Marcelasourus :)
    AND THIS thing reads afr?
  13. Jun 18, 2013 at 10:07 PM
    #313
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Wait, was it a kindle fire 2?
    I was wondering if that would work.
  14. Jun 19, 2013 at 5:53 AM
    #314
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    It will read AFR if there is a built in wideband. Not sure about the new tacos, but 1st Gens and most second Gens only have a narrowband sensor stock. I think it's able to read a narrowbands voltage out put , but that doesn't really tell you much besides whether or not your AFRs
    are within the factory spec, not the actual reading
  15. Jun 19, 2013 at 6:46 AM
    #315
    skygear
    skygear                    
    Yeah, i was not sure on the afr ordeal. Not sure if upgrading the sensor is available either...
    I was wanting to see the screen shots of some of the others to see what they are doing with the gauges.
  16. Jun 19, 2013 at 6:48 AM
    #316
    skygear
    skygear                    
    Interesting to see if someone retro fits a TFT screen for the gauge cluster and has it running Torque. That would be interesting. Bring Mercedes and others tech to the masses.
  17. Jun 19, 2013 at 7:08 AM
    #317
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Upgrading the sensor wouldn't work since the factory ecu is only able to read the narrowband. You would need to add a new bung, wide band sensor, and a gauge that can read the sensors analog output
  18. Jun 19, 2013 at 7:17 AM
    #318
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    The ELM327 is like $11 on Amazon...why are y'all determined to over pay? Lol
  19. Jun 19, 2013 at 7:17 AM
    #319
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I've seen it on some forums where people run small Android tablets add their stereo in their dash and have torque running as well.
    I run it on my old Android. wouldn't be that hard to make up a custom steering wheel gauge pod for the phone. But fiber glassing or similar is something I don't have three patience for, do I just run it in a window auction cup mount.
  20. Jun 19, 2013 at 10:45 AM
    #320
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Some of the cheap ones don't refresh fast enough, break easily, won't connect, etc...
    I've got the kiwi Bluetooth one. World well, had a high refresh rate for data logging, and was only like $100.
