Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. May 20, 2014 at 6:41 PM
    #401
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    I think thats about right on a cooler day not towing. Warmer days, I think I had 185 ish. Towing, I think I remember around 220ish. Let me know what you get for comparison please.
  2. May 20, 2014 at 7:01 PM
    #402
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Will do. I was getting 156 I think this afternoon. Any luck getting the engine oil temp to read?
  3. May 20, 2014 at 7:11 PM
    #403
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I don't know about the engine oil temp.
    But the trans temp sounds about right, mine stayed around 140 on the freeway today (running 75 ish on a slight incline)
  4. May 20, 2014 at 7:19 PM
    #404
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    I may be wrong, but I don't think we have the sensor for engine oil temp. Just the idiot light sending unit.
  5. May 20, 2014 at 7:31 PM
    #405
    MattN03
    Bluegrass State
    Wouldn't that idiot light have to get a signal though? I'd think we could read it? The idiot light must have a predetermined temp it comes on at, so somehow that is being read?
  6. May 21, 2014 at 12:02 AM
    #406
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Yes, but there are variable sending units and fixed sending switches. One has a spring and when the pressure reaches a certain number it is no longer strong enough to push the spring and the contact is made illuminating the light. It's like slowly pushing on a standard light switch, eventually the light will turn off, no dimming happens.
  7. May 21, 2014 at 3:30 AM
    #407
    MattN03
    Bluegrass State
    Gotcha, that makes sense. Bummer!
  8. May 26, 2014 at 4:47 PM
    #408
    MattN03
    Bluegrass State
    [QUOTE="OldManTan";8686603]I think thats about right on a cooler day not towing. Warmer days, I think I had 185 ish. Towing, I think I remember around 220ish. Let me know what you get for comparison please.[/QUOTE]
    I towed my 16' trailer and Kawasaki Teryx 4 to the eastern KY mountains this weekend. I towed most of the trip with 5th locked out. Speeds ranged from 50-70 MPH on 2 lane roads and about 30 miles of interstate I-75 with some decent grades. I never saw the temp get above 190, and most of the time it was 160-170.
    The trailer and T4 should weigh around 3400 lbs I'd estimate with all the riding gear, spare tire, fuel, and tools.
  9. May 26, 2014 at 5:03 PM
    #409
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Hmm, I may have to look into this more. I think something is up with my tranny anyway. When I'm backing out, when I flip in D sometimes it hesitates before lurching forward.
  10. May 31, 2014 at 4:43 AM
    #410
    oldstick
    oldstick Medicare Member
    GA
    I tried the equation from post 403 today on my 07. I get two different readings that seem reasonable, but they seem to be in Centigrade degrees for some reason. The readout warms up to 58 degrees (parked and idling) or so, which I think is around 140 F. The needle gage even say's it's "deg C" although the scale numbers do range from 0 to 220 as specified in the entries.
    Any ideas?
  11. May 31, 2014 at 5:33 AM
    #411
    MattN03
    Bluegrass State
    Go to Settings from the opening menu, and then go to Units. Confirm your units are in °F.
  12. May 31, 2014 at 5:33 AM
    #412
    oldstick
    GA
    Never mind, I think I fixed it. You have to go to the Torque global settings for units and turn off the check block "Use Centigrade"
  13. May 31, 2014 at 5:34 AM
    #413
    oldstick
    GA
    Thanks very much Matt, you beat me to it...
    :D
  14. May 31, 2014 at 5:36 AM
    #414
    MattN03
    Bluegrass State
    Good deal!
  15. Jun 9, 2014 at 7:38 PM
    #415
    Whylucky
    Whylucky Member
    Lucky
    Texas
    2014 Metallic Gray Double Cab V6 Tacoma
    Westin Brush Guard, Bumper Protector
    So I have been reading through some of this thread and had some more questions, does the bluetooth still draw power when the car is off? Is this dependent on the dongle? Does the Torque app measure fuel tank volume so i can write a code for miles left in tank? Thanks for all the help, im driving a 2014 Taco
  16. Jun 12, 2014 at 7:23 AM
    #416
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Just ordered mine....
  17. Jun 14, 2014 at 9:10 AM
    #417
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Can any of you answer me this? When my peddle is on the floor I'm only at 76% throttle according to the app. Is this normal or should I be able to get closer to 100%?
  18. Jun 14, 2014 at 9:18 AM
    #418
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Maybe u could cut the floor panel out from behind the pedals and refab it lower so u can puh it further
  19. Jun 19, 2014 at 2:13 PM
    #419
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Has anyone on here done anything like this?
    http://www.ft86club.com/forums/showthread.php?t=29723
    Looks pretty neat. I'm trying to decide if I wanna get a new head unit or try to integrate an old android phone I have into a permanent dash fixture to run torque/hold music.
  20. Jul 2, 2014 at 10:07 PM
    #420
    Cjones
    Cjones New Member
    4x4 3.4L
    I have been having a ton of trouble getting torque working on my '00 Tacoma. I bought the bafx obd2 bluetooth adapter directly from Amazon and I'm using the pro version of the app. I am using a Samsung s2. I've also tried a Samsung Note 4 with no luck.
    The app connects to the adapter fine but the adapter is never able to communicate with the ECU. The adapter/app works fine with my '11 Silverado.
    OBD clearinghouse says my truck uses ISO 9141 OR KWP2000. I've tried hardcoding the app to ISO 9141 & ISO14230-4 with no luck.
    I believe my OBDii port is good - the guy at autozone was able to pull codes from it with no problems last week.
    I've done all the obvious things like rebooting my phone/trying with key in the on position and with the engine running. I'm starting to run out of ideas. Should I try anything else?
    Edit: Forgot to mention - The truck was manufactured in California on 6/00 so its definitely not JDM.
